ST2000DM001-9YN164 HDD is starting after 5 minutes.
Posted: 03.12.15, 13:15
by eisltd_adam
Hi all.
I have problem to start this HDD. It has problems with reading as well.
Terminal output shows this:
Starting LBA of RW Request=000000000008785E Length=00000038
ProcessRWError -Read- at LBA 0000000000087860 Sense Code=43110081
Starting LBA of RW Request=0000000000087862 Length=00000034
ProcessRWError -Read- at LBA 0000000000087863 Sense Code=43110081
Starting LBA of RW Request=0000000000087866 Length=00000030
ProcessRWError -Read- at LBA 000000000008786F Sense Code=43110081
Can someone help with this drive, please.
Re: ST2000DM001-9YN164 HDD is starting after 5 minutes.
Posted: 04.12.15, 13:58
You will notice length field is a timer. When this reaches zero (or close to zero) drive should report ready. You will need to look at relocation parameters at SMP module to address this.
Posted: 04.12.15, 15:04
by eisltd_adam
Hello AJ. I think this hdd has a lot of bad sectors. I've found this module. I don't know what is the next step. I have two of them. Both of them I can read and I've saved them to sys folder.
Posted: 04.12.15, 15:40
You need to edit parameters of it with 'edit Saved Mode PAges' option. Or you can select 'Edit HDD ID over terminal' option. This will return to you a window with lots of checkmarks. Remove all or you can choose which aspects of it to disable.
Posted: 04.12.15, 15:41
Also, if there are lots of relocated sectors you can assume that surface will have many errors also (like bad sectors).
