Short points for ST5000DM000
Posted: 01.12.15, 18:47
by msurgeon
Would greatly appreciate short points on PCB 100721570 as per attached
Fortunately, just found answer on current blog post!
Re: Short points for ST5000DM000
Posted: 25.12.15, 08:49
by Filipp_TS
Take a look please this article:
http://ts.acelab.eu.com/index.php?/ ... -f3-drives
Also you can contact Technical support department regarding this and other cases.
Posted: 26.12.15, 17:29
by cuumaytinh
Great ! :thumbup: :thumbup:
Posted: 10.05.18, 00:10
by Sam A
Article is gone. Please re-post
Posted: 10.05.18, 02:00
by LarrySabo
Sam, it's in the Blog: http://blog.acelab.eu.com/where-and ... rives.html
... unless it's a different article.
Posted: 10.05.18, 14:33
by Sam A
Thanks Larry. I just realized the original link pointed to the general shorting guide for F3 drives. I was hoping for a technique specific for this PCB/drive...I wasn't making any progress using the general guide.
Posted: 10.05.18, 15:41
by LarrySabo
I suspected that was the case. Sorry I couldn't help.
Posted: 10.05.18, 17:47
by Sam A
That's OK Larry... it was nice to hear from you at least :wave:
Posted: 10.05.18, 23:58
by msurgeon
Enlarge picture at top; short points are 6th and 7th from the top on the left row. It's been a while since I did this but If not 6th and 7th, then 8th and 9th. You'll hear clicking when you hit the right points.
Posted: 11.05.18, 13:09
by LarrySabo
... or power the unmounted PCB and measure the voltage to ground of the obvious trace pair you think is the read/write channel. The read channel traces will have 0v and the write channel traces will have a small bias voltage, e.g., ca .5v.
