St4000dm000 After Head change Message Disc FW failed to load
Posted: 17.11.15, 14:44
by Arihant
Seagate 4TB hdd has clicking noise. It has head crashed. I have replace the head.
Now No cliking noise. Motor is runing smoothly. Terminal shows this message.
"Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Disc FW failed to load"
How to resolve?
Re: St4000dm000 After Head change Message Disc FW failed to load
Posted: 17.11.15, 16:58
by Sergey_TS
You need to get terminal access and check heads reading and writing via terminal. Then check important sysfiles. Maybe you will need to upload loader
Posted: 25.11.15, 10:51
by Arihant
REplaced the pcb and solved.
Thanks,
Posted: 13.07.16, 22:15
by osity
Did you need to swap 1 ROM chip or 2?
Posted: 14.07.16, 12:24
osity wrote:Source of the post Did you need to swap 1 ROM chip or 2?
What,
I Think They Have Only 1 Rom
Posted: 14.07.16, 12:42
by osity
I thought so too.
my drive stopped spinning after it was imaging fine for a while. I remove the TVS and it was fine for a few minutes and then stopped spinning again.
I changed the PCB/rom and the drive now spins again but I get this FW Error and the drive now detects as 3.68GB.
