Flash boot code Digital Signature Verification failure!
Posted: 16.06.26, 11:43
by kailash
Can someone provide a solution for Seagate 2TB Mobile ST2000LM007 PN:1R8174-570 FW:EB01 Site:TK FW:EB01 DOM:15NOV2022 PCB:100835923 REVB
Drive comes to ready with full ID but none of the sectors are accessible.
ROM is NOT readable through the terminal. I wrote unlock patched to the ROM externally and yet I can't send the UNLOCK signal through the PC-3000 terminal to the drive.
I used a matching DONOR pcb with transferred patient's ROM but I get this error message:
0x00000040
0x00020000
0x00000001
0x00000001
0x00000001
0x00000020
0x00000020
0x00000020
0x00000020
0x00000020
SEA5 Boot ROM 1.0 (06/01/2017)
Copyright Seagate 2017-VM000
SBP3: Init HRK Failed: 0x0107
and the drive doesn't even turn on.
Here is my question, is there a way to change the Digital Signature of the patient's ROM to make it compatible with DONOR pcb controller's Digital Signature?
Thank You!
Screenshot 2026-06-16 153512.png (82.24 KiB) Viewed 5350 times
Re: Flash boot code Digital Signature Verification failure!
Posted: 20.06.26, 15:08
by italyassistance
Are you sure you copied the patient's ROM to the donor correctly? Why did you change the PCB?
Posted: 25.06.26, 08:08
by kailash
I suspected there might be a problem with the PCB, so I replaced it; could you please fix my ROM? BIt's possible the ROM didn't copy correctly when I was copying it.
I would be very grateful to you.,
Posted: 25.06.26, 08:09
by kailash
ROM
UNLOCK.rar
(274.62 KiB) Downloaded 641 times
prasant.rar
(272.74 KiB) Downloaded 628 times
Posted: 26.06.26, 18:51
by italyassistance
how copy the rom with the terminal? tomorrow i will check your rom with my portable
Posted: 27.06.26, 08:34
by italyassistance
kailash wrote:Source of the post ROM
i check your rom and is is bad have some header invalid, what kind of problem have hdd?
