ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE
Posted: 15.02.24, 02:47
by datasalvage
Hello guys hows your new year?
i received this drive that doesnt spin at all and stay BSY with error LED:0x000000BD FAddr:0x000059D8
iv tried the official guide https://blog.acelab.eu.com/how-to-fix-a ... -chip.html
but with donor PCB "after Repeat the unlocking steps (1-6) " i cannot enter the command OI1 ..... i will get LED:0x000000BD FAddr:0x000059D8 !AGAIN
and if i skip this command and Repeat the unlocking steps (7-9). the drive spinds but i get Waiting drive spin up ! therefore i cannot use the terminal !
with original PCB is the same.....the drive spins if i change to 82 34 56 78 but i cant enter the command OI1
i also noticed that nomatter how many times i write the patient rom into DONOR PCB it will show the SN of the DONOR.........
any help will be very very helpfull
Re: ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE
Posted: 16.02.24, 09:02
by lifeguarddata
this is Hybrid Drive.
Posted: 16.02.24, 18:28
by ajay.mudhgill
i can help u
Posted: 17.02.24, 04:53
by osity
datasalvage wrote:Source of the post nomatter how many times i write the patient ro
I just did one of these just over a week ago. I wouldn’t worry about the incorrect passport
Posted: 17.02.24, 13:55
by datasalvage
ajay.mudhgill wrote:Source of the post i can help u
hello sir how can yoou help me ?
Posted: 17.02.24, 13:57
by datasalvage
osity wrote:Source of the post
How did you solved the problem Sir?can you suggest some trick? the patient drive has same pcb numer.same model and same firmware
Posted: 20.02.24, 06:32
by datasalvage
can somebody tell me which is the correct position for the read channell? i tried many times but is still get the error LED:0x000000BD FAddr:0x00008004
should i short before or after the tech Unlock Handshake"?
should i keep the position untill the drive get ready ? if the position is correct will the drive keep spinning or will stop spins?
Posted: 22.02.24, 02:52
by osity
Those above contacts are for the motor. Are you trying to short the motor? Short after initialization. You may want to incorporate a paperclip into your tweezers. There should be a blog post that should help you with this also.
