Rosewood_a5 Unsupportde firmware
Posted: 20.12.23, 22:15
I have this one TB seagate ST1000LM035 PN: 1RK172-070, FW: LVM1, SITE: WU , ID is not detected, but spinning normally and i could access the terminal, i backed up necessary modules, but when i try to edit SMP , and save it gives error in red "un supported by firmware", it is running smoothly, but no id, i could backup all modules from head 01, module 28_00 is not read, but 28_01, could read, when i try to write it to 00, also gives me error "unsupported by firmware", also 348_00.rpm could not be read, but 348_01 could be read. The disk is not writing in indirect or direct method.
can any one tell me how to deal with this issue
thank you
I used "Solve the Device Fault State (DWF) Issue" it reads id and sn but zero capacity , also could not write back to SA any module
But I co
thank you
But I co
