ROM Read Issue and donor compatability on Rosewood A5 ST2000LM007 Drive
Posted: 27.01.23, 19:01
by Data Angel
EDITED TO BETTER REFLECT TO FULL CASE:
Obviously wish I would have tried to get the ROM first but it was an obvious head crash (Head 1 & 3). Inspected and saw a lift on 0 and a slight lift on 2.
Re: Whos Hoarding some ST2000LM007 Drives?
Posted: 31.01.23, 12:58
by digitalsupport
Put donor heads back in donor drive and check if working, did you check preamp?
Posted: 31.01.23, 18:47
by Data Angel
Thanks Allan! (im assuming its not an employee) Preamp of donor is C2 12. here's the dump. Is there any way to get the preamp type of the patient without working heads? or is this just a try it until it works situation? Apricate your replies!
CheopsLiteM.1.0.SATA.Rosewood.Mule.Servo376.Rap30.AP1.4K + SMR
Product FamilyId: A5, MemberId: 01
HDA SN: WDZ024Z8, RPM: 5456, Wedges: 178, Heads: 4, OrigHeads: 4, Lbas: 00001D5754FF, PreampType: C2 12
Bits/Symbol: C, Symbols/UserSector: 0, Symbols/SystemSector: 0
PCBA SN: 0000K70691LK, Controller: CHEOPSLITEM_1_0_SATA(1310), Channel: Unknown, PowerAsic: KONA Rev A042, BufferBytes: 8000000
SF ID: 62 16, SF Part Size: 400, Flash Used: 400
Package Version: RT0898.SDM2.CC4603.SBK2 , Package P/N: ---------, Package Global ID: 00306432,
Package Build Date: 07/12/2016, Package Build Time: 20:24:03, Package CFW Version: RT08.SDM2.01071001.00306432,
Package SFW1 Version: 8940, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 07122024, CustomerRel: SBK2, Changelist: 01071001, ProdType: RT08.SDM2, Date: 07/12/2016, Time: 202403, UserId: 00306432
Servo FW Rev: 8940
TCG IV Version: 30.05
Package BPN: 7
RAP FW Implementation Key: 1E, Format Rev: 0208, Contents Rev: 53 05 01 00
Active BFW Container: 0
4K Sys Area: 1
Features:
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled v. 5.0.03.0000000000000003
- LTTC-UDR2 disabled
- SuperParity 4.1 enabled OTF OC enabled
TotalSuperBlks TotalValidSuperBlks
0018123A 00180DCA
- UMP Zone Group 0004 to 0005
TotalSuperBlks ValidSuperBlks
Posted: 01.02.23, 07:55
by digitalsupport
You can check if preamp is default or alternative in F3 utility.
Launch F3 and select family.
Tools > Utility > Work with Flash ROM image file
Load ROM from file or read from PCB
Click "Show information" button
In the SAP section you will find "Head vendor.............. :" can be "default" or "Alternativ"
\\ Allan :wink:
Re: ROM Read Issue and donor compatability on Rosewood A5 ST2000LM007 Drive
Posted: 03.02.23, 23:15
by Data Angel
figured it out.
