Broken translator area (both copies) in Rosewood drives ...
Posted: 12.09.22, 11:09
I have a problem with the 2.5 "Seagate Rosewood ST2000LM007.
Disk starts (normal sounds), full ID - except capacity (0 MB).
I copied almost full SA, without errors - unfortunately except both copies of the translator are unreadable.
I have module of translator from 0 copy. I was able to read almost everything - except the first few sectors.
I'm including this damaged module - 02B err.rpm.
Sorry to have to convert the attached file from .rpm to .txt but the forum doesn't accept .rpm ...
(Copy translator of 1 is more damaged.)
I did not perform any activities related to SA.
I am asking for tips and help - how can I restore access to my data.
Thank you in advance
Regards for all
Igen
Regards for all
Igen
- 02B err.txt
- (948 KiB) Downloaded 223 times
