ST4000DM004 v11 not spinning up.
Posted: 12.07.22, 07:35
I have this drive that does not spin up with the original PCB, it does spin with a donor PCB. ROM Swap makes the donor act the same as the original PCB
When I start up the drive in Boot mode, I get this report
Switching HDD power supply ON
Drive ID reading errorr Operation aborted
Flash type inx... 0x00000001
Flash size....... 0x00200000
Flash prm dmp.... 0x62 0x16 0x10 0x0B 0x05 0x9F 0x01 0x02 0x1C 0x20 0x40 0x04 0x00 0x01 0x00 0x15
Receiving file flash.bin, length = 2097152
Parsing container segment....... Flash ROM image
WARNING! Segment header check sum is invalid!
Segment: GLOB_FLASH_DIR
Parsing segment....... GLOB_FLASH_DIR
End parsing segment... GLOB_FLASH_DIR
Segment: BOOTFW_CONT_0
Parsing container segment....... BOOTFW_CONT_0
Segment: BOOTFW_DIR
Parsing segment....... BOOTFW_DIR
End parsing segment... BOOTFW_DIR
Segment: GENERAL_DATA
Parsing segment....... GENERAL_DATA
End parsing segment... GENERAL_DATA
Segment: PROG_INQ_DATA
Parsing segment....... PROG_INQ_DATA
End parsing segment... PROG_INQ_DATA
Segment: BOOTFW
Segment: IAP
Parsing segment....... IAP
End parsing segment... IAP
Segment: SFW
Parsing segment....... SFW
End parsing segment... SFW
Segment: SHELL
Parsing segment....... SHELL
End parsing segment... SHELL
End parsing container segment... BOOTFW_CONT_0
Segment: BOOTFW_CONT_1
Parsing container segment....... BOOTFW_CONT_1
Segment: BOOTFW_DIR
Segment: BOOTFW
Segment: IAP
Segment: SFW
Segment: SHELL
End parsing container segment... BOOTFW_CONT_1
Segment: RAP
Parsing segment....... RAP
End parsing segment... RAP
Segment: UDS_BFW
Parsing segment....... UDS_BFW
Segment: SAP
Parsing segment....... SAP
End parsing segment... SAP
Segment: CAP
Parsing segment....... CAP
End parsing segment... CAP
Segment: BOOTFLOADER
Parsing segment....... BOOTFLOADER
End parsing segment... BOOTFLOADER
End parsing container segment... Flash ROM image
FLASH ROM Info
Image size............... : 2097152
QNR Revisions:
Flash ROM image.......... : 3
GLOB_FLASH_DIR........... : 3
BOOTFW_CONT_0............ : 0
GLOB_FLASH_DIR........... : 2
BOOTFW_CONT_1............ : 0
CAP
Validation Key........... : 0x00000020
Fam ID................... : 0x9B (V11)
Fam Member............... : 0x1
Head count............... : 4
Date (ERROR!)............ : 08 - 18 -
SN....................... : WFN02PTV
PCB SN................... : 0000E830B92V
PCB PN................... : 100815596
WWN...................... : 5000C500B9273D7E
MDL1..................... : ST4000DM004-2CV104
MDL2..................... : ST4000DM004
Capacity................. : 7814037168
RAP
Format revision.......... : 0x0206
Contents revision........ : 0x1F151700
Number Sys Zones......... : 1
Number User Zones........ : 250
Heads count.............. : 12
FW Implementation Key.... : 0x1E
SAP
Addr 0................... : 0x00112F00
Addr 1................... : 0x80000000
Fam ID................... : 0x9B, (V11)
Fam Member............... : 0x4
Servo FW rev code........ : 0x7926
Max head................. : 3
Seek mode................ : 2000
Flags.................... : 9A79
Head vendor.............. : default
RRO mode................. : 0005
Heads polarity........... : 00 00 00 00
Logical head map......... : 00 01 02 03
IAP
ID, code................................ : 0xFFFF
PUIS.................................... : OFF
Active config........................... : 8D40FFFF
NAND ROM cache flag, Kahuna like........ : FFFFFFFF
NAND ROM cache flag, Rosewood like...... : FFFFFFFF
IAP 1
ID, code................................ : 0x00FF
PUIS.................................... : ON
CODE info
Bank 0
ProdType................. : V0A80C2.DPC7
Controller FW Rev........ : 02072208
Customer Release......... : 0001
Changelist............... : 01193246
Build date / time........ : 7/02/2017 10:08:23 PM
Package Global ID........ : 00494291
Package Builder ID....... :
Build Rev................ :
Package Rev.............. : AE000L
Pkg P/N.................. : ---------
Servo FW................. : B21F / ---- / ---- / ----
Package Version.......... : V0A80C2.DPC7.AE000L.0001DPC7
Pkg CFW Ver.............. : V0A80C2.DPC7.01193246.00494291
Bank 1
Saving ROM to profile folder
File : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\V11\ST4000DM004-2CV104-0001-WFN02PTV\Data\ROM\ROM_WFN02PTV_383B7601.bin
Selected family......................... : 9B, V11
Model by ID............................. : ST4000DM004-2CV104
Loading default settings!
Then press OK!
Any ideas? I know that I need to patch the ROM, but do not want to damage it.
Segment: BOOTFW_DIR
Segment: BOOTFW
Segment: IAP
Segment: SFW
Segment: SHELL
Segment: BOOTFW_DIR
Segment: BOOTFW
Segment: IAP
Segment: SFW
Segment: SHELL
Segment: RAP
Segment: UDS_BFW
Segment: SAP
Segment: CAP
FLASH ROM Info
QNR Revisions:
CAP
RAP
SAP
IAP
IAP 1
CODE info
Bank 0
Bank 1
Then press OK!
