(rewrite) ST5000LM000-2U8170 2.5 HDD ROM Read Problem Asking for Help
Posted: 03.03.22, 10:35
by OHMYDATA
PC3000 EXPRESS Version 6.9.16
I am trying to patch the lock because the sector cannot be accessed.
In order to patch, you need to read the ROM with a terminal.
Can't read rom with terminal
The following message is output.
I've tried all the terminal read speeds. The same error message is output.
DOM : 23AUG2021
PCB : 100870309 REVA
log
Software can`t control COM port signal level for this USB/COM adapter
HDD family detecting...
Family ID: CF
WARNING! Unknown family!
Model by ID............................. : ST5000LM000-2U8170
Tech Key...
Requesting FW Pkg ver ........ M2AEA13B0.SDM4.410013.0001
Detecting SA Phys Sct Size...
Can not detect SA phys secotr size by ATA!
Terminal
ASCII Diag mode
F3 T>
Bad cmd: 0x0303
How I've tried so far
- BOOT CODE mode on startup
- Read 3.3v, 2.5v, 1.8v rom with terminal 3
I need an unlock patch, but I can't read the rom. Is there any other way?
Re: (rewrite) ST5000LM000-2U8170 2.5 HDD ROM Read Problem Asking for Help
Posted: 09.03.22, 18:08
by msurgeon
If you haven't done it already, try isolating head contacts and try again. This has worked in the past with similar problem.
