Seagate 0MB problem
Posted: 11.02.22, 11:02
by d1d
hi guys,
i have a ST2000LM007-1R8174 here, capacity says 0MM (- 1).
i tried the solution from Acelab but if itry to patch the ROM the Log says : Tech Mode unlocking preparation, (patch).................... : Error
any suggestions ?
thank you
Re: Seagate 0MB problem
Posted: 11.02.22, 11:57
by d1d
it worked now and i got the Tech Mode unlocking preparation, (patch).................... : Ok message but if i take power OFF/ON the terminal still says:
Boot0x80M
TCC:001F
[LBA=0x00000001][LBA=0x00000002][LBA=0x0000040D][LBA=0x0000040D]
DSC PASS
SIMFileFD=FC00320DErrorCode=43110081DiscLBA=000000000000040DDuration=00000192ms[LBA=0x0000DE06][LBA=0x0000DE06]
SIMFileFD=FC00320DErrorCode=43160080DiscLBA=000000000000DE06Duration=00000046ms
SimError-RemaininginBootFW
Performadoubledownloadwithoutapowercycle
Posted: 14.02.22, 12:03
by Maxim_TS
d1d wrote:Source of the post SimError-RemaininginBootFW
This message means that the heads can't see overlay on platters.
it may be if:
1) ROM is damaged or not original. Compare the SN in ROM with SN on lid sticker.
2) Bad heads. Head swap may help in this case.
3) Damaged overlay area on the surface. Nothing can be done in this case unfortunately.
Posted: 15.02.22, 10:08
by d1d
Maxim_TS wrote:Source of the post 3) Damaged overlay area on the surface. Nothing can be done in this case unfortunately.
that's the issue unfortunately
Posted: 10.05.24, 08:45
by gameboybin
I have exact same problem. After changing heads> Clicks a few times and got ready on Double down
