ST2000LM007-1R8174 sectors show $...m..mo.L.D..;
Posted: 04.10.21, 11:18
by Abdurrahim.sopon
I have a hdd with many sectors show ($...m..mo.L.D..; )
have any solution for this issue ?
- 2021-10-04_152352.jpg (456.69 KiB) Viewed 184113 times
Re: ST2000LM007-1R8174 sectors show $...m..mo.L.D..; Topic is solved
Posted: 05.10.21, 22:25
by lcoughey
If there is a lot, change heads. If there is a small amount, you might be able to re-read those sectors.
Posted: 08.10.21, 08:27
by Abdurrahim.sopon
lot of sectors
Posted: 10.10.21, 20:51
by Tawfeek
i faced same , chang heads and it act the same . i'm sure it's not heads
Posted: 21.10.21, 19:47
by Filipp_TS
That might be head(s) issue - one or few head(s) can't pass internal heads test after power on or/and not compatible (if current heads are from the donor drive)
also (less possible) that could be an issue related to corrupted/damaged MCMT
