Video 2.5 (ST500VT000)
Posted: 11.02.21, 16:39
by zengindistic
Our drive is referred to as Seagate ST500VT000 Video 2.5.
I have read and tried all the topics in the articles. I could not find a solution.
Thinking that there was an Ata password that could not be fully opened, I found the same disk without problems.
This means that the problem can be solved.
How can we fix the problematic disk by using the unlocked or problem-free disk we have?
Or does anyone know the solution to this problem?
Re: Video 2.5 (ST500VT000)  Topic is solved
Posted: 11.02.21, 17:47
try to unlock with same method of rosewood case and check for access to SA - what error do you see on sector access?
Posted: 11.02.21, 19:24
by zengindistic
AJ2008 wrote:Source of the post try to unlock with same method of rosewood case and check for access to SA - what error do you see on sector access?
Normally, https://blog.acelab.eu.com/pc-3000-for- ... rives.html
I saved a lot of disk as in this thread.
When I try to do this solution to this disk,
Code: Select all
No editing objects are found!
Tech Mode unlocking preparation, (patch).................... : Error
I see this error.
All service information object area is empty...
I see the classic Seagate error screen at the first opening.
