Rosewood drive, media cache and LED:0x000000BD FAddr:0x0000599A problem
Posted: 13.08.20, 16:58
Hi everyone,
some problems with a rosewood drive and, i suppose, media cache related problems.
This is a ST1000LM035-1RK172 drive.
When it come to us was unable to read ID. After unlocking procedure ID became fully read but terminal showed led problem:
Boot 0x80M
Tech Unlock Handshake: 0xA67DB935
Reply:
QB
Rst 0x80M
Srv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
(POR) Recover Secondary MCMT Opened Recovered
MSP213
(MC POR Duration): 00000000E2
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
PowerState = IDLE1
VC0
PowerState = IDLE1
VC0
(DOS) File Save Wrst Ct: 0000 SU: FFFFFFFF NT: 00000000 OT: 00000000
HighPowerMode
XI2
VC1
VC2Up:Status 0001 Req 0002
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
XI2Status 0001 Req 0038ACTIVE
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
HighPowerMode
VC1
VC2Up:
XI2Status 0001 Req 0002
PrgF
I had to press ctrl+z several times anyway to enter in T level and not always this is successfull.
SA Backup (0+1) was fully performed and all modules are ok
93 module was downloaded and unticked in all checkbox but "media chache" (leaving it checked)
After this I can read, just 1 sector from all user area. At second lba read hdd become busy and terminal start showing again same LED problem written before
To read another sector i need to reboot on/off and to reload all resources from disk after unlocking again.
I followed 348, 2b, 28, 35 system files rewrite from backuped resources without problem but reading user area problems are the same.
As adviced from ACE technicians, I haven't perform anything on traslator even because performing V4 and V40 commands I got entries:
F3 T>V4
Reassigned Sectors List Enabled
Entries: 01E0, Alts: 01DF, Removed: 001C,
Pending: 0004, Host Pending: 0010, Max RSL Size: 00002000
Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msecs Status BBM Mask
0000 00000239FF7F 000002EFA846 00F23D.1.0000 07C 0104DF.1.0000 06BD5B ----- ------ 00000021 00000000
0001 00000239FFEC 00000EB6A683 00F23D.1.FFFF 0E2 061F37.1.0014 024C2F ----- ------ 00022010 11111111
0002 0000031F3489 00000EB6A855 013E61.1.FFFF 0CB 061F39.1.005C 07AF53 ----- ------ 00002010 11111111
0003 0000031F348A 00000EB6A856 013E61.1.FFFF 0CC 061F39.1.005D 07BCAD ----- ------ 00002010 11111111
0004 0000031F34F0 00000EB6A857 013E61.1.FFFF 12F 061F39.1.005E 07CA07 ----- ------ 00002010 11111111
0005 0000031F354F 00000EB6A858 013E62.1.FFFF 032 061F39.1.005F 07D761 ----- ------ 00022010 11111111
0006 0000031F3550 00000EB6A859 013E62.1.FFFF 033 061F39.1.0060 07E4C1 ----- ------ 00022010 11111111
0007 0000031F3551 00000EB6A85A 013E62.1.FFFF 034 061F39.1.0061 07F1DB ----- ------ 00022000 11111111
0008 0000031F3552 00000EB6A85B 013E62.1.FFFF 035 061F39.1.0062 07FF35 ----- ------ 00022000 11111111
0009 0000031F3553 00000EB6A85D 013E62.1.FFFF 036 061F39.1.0064 0819E9 ----- ------ 00022000 11111111
000A 0000031F3554 00000EB6A85E 013E62.1.FFFF 037 061F39.1.0065 082743 ----- ------ 00022000 11111111
000B 0000031F3555 00000EB6A85C 013E62.1.FFFF 038 061F39.1.0063 080C8F ----- ------ 00022000 11111111
000C 0000031F3556 00000EB6A85F 013E62.1.FFFF 039 061F39.1.0066 08349D ----- ------ 00022000 11111111
000D 0000031F35EF 00000EB6A860 013E62.1.FFFF 0CD 061F39.1.0067 0841F7 ----- ------ 00022000 11111111
000E 0000031F35F0 000003D61113 013E62.1.00A2 0CE 015104.1.00A2 0AF04A ----- ------ 00000021 00000000
000F 00000578E47D 00000EB6A862 01E83D.0.FFFF 072 061F39.1.0069 085CAB ----- ------ 00002000 11111111
0010 00000BA76546 00000EB6A866 04A9C4.1.FFFF 037 061F39.1.006D 0891D3 ----- ------ 00002000 11111111
0011 00000CD12647 00000EB6A840 055867.1.FFFF 032 061F39.1.0047 069771 ----- ------ 00002010 11111111
0012 00000CD12648 00000EB6A841 055867.1.FFFF 034 061F39.1.0048 06A4CB ----- ------ 00002010 11111111
0013 00000CD12649 00000EB6A842 055867.1.FFFF 036 061F39.1.0049 06B225 ----- ------ 00002010 11111111
0014 00000CD1264A 00000EB6A843 055867.1.FFFF 037 061F39.1.004A 06BF7F ----- ------ 00002010 11111111
0015 00000CD1264B 00000EB6A844 055867.1.FFFF 039 061F39.1.004B 06CC99 ----- ------ 00002010 11111111
0016 00000CD1458B 00000EB6A869 055843.1.FFFF 053 061F39.1.0070 08B9E1 ----- ------ 00002000 11111111
0017 00000CD1458C 00000EB6A86A 055843.1.FFFF 054 061F39.1.0071 08C73B ----- ------ 00002000 11111111
0018 00000CD14590 00000EB6A86B 055843.1.FFFF 05B 061F39.1.0072 08D495 ----- ------ 00002000 11111111
0019 00000CD14591 00000EB6A86C 055843.1.FFFF 05D 061F39.1.0073 08E1EF ----- ------ 00002000 11111111
001A 00000CD14592 00000EB6A86D 055843.1.FFFF 05F 061F39.1.0074 08EF49 ----- ------ 00002000 11111111
001B 00000CD14593 00000EB6A86E 055843.1.FFFF 060 061F39.1.0075 08FCA3 ----- ------ 00002000 11111111
001C 00000CD14594 00000EB6A86F 055843.1.FFFF 062 061F39.1.0076 0909BD ----- ------ 00002000 11111111
001D 00000CD145A1 00000EB6A872 055843.1.FFFF 078 061F39.1.0079 0931CB ----- ------ 00002000 11111111
001E 00000CD147D5 00000EB6A873 055840.1.FFFF 02C 061F39.1.007A 093F25 ----- ------ 00002000 11111111
001F 00000CD168AE 00000EB6A878 05581A.1.FFFF 04A 061F39.1.007F 0981E7 ----- ------ 00002000 11111111
0020 00000CD1A2DD 00000EB6A848 0557D7.1.FFFF 160 061F39.1.004F 070201 ----- ------ 00002010 11111111
0021 00000CD1A2FD 00000EB6A845 0557D7.1.FFFF 01D 061F39.1.004C 06D9F3 ----- ------ 00002010 11111111
0022 00000CD1A4A8 00000EB6A84A 0557D5.1.FFFF 040 061F39.1.0051 071CB5 ----- ------ 00002010 11111111
0023 00000CD1A4A9 00000EB6A84B 0557D5.1.FFFF 042 061F39.1.0052 072A0F ----- ------ 00002010 11111111
0024 00000DCF1842 00000EB6A84C 05F64B.1.FFFF 0C2 061F39.1.0053 073769 ----- ------ 00002610 11111111
0025 00000DCF1843 00000EB6A84D 05F64B.1.FFFF 0C4 061F39.1.0054 0744C3 ----- ------ 00002610 11111111
0026 00000DCF1844 00000EB6A84E 05F64B.1.FFFF 0C6 061F39.1.0055 07521D ----- ------ 00002610 11111111
0027 00000DCF1845 00000EB6A84F 05F64B.1.FFFF 0C8 061F39.1.0056 075F37 ----- ------ 00002610 11111111
0028 00000DCF18DE 00000EB6A850 05F64A.1.FFFF 099 061F39.1.0057 076C91 ----- ------ 00002610 11111111
0029 00000DCF18DF 00000EB6A851 05F64A.1.FFFF 09B 061F39.1.0058 0779EB ----- ------ 00002610 11111111
002A 00000DCF18E0 00000EB6A852 05F64A.1.FFFF 09C 061F39.1.0059 078745 ----- ------ 00002610 11111111
002B 00000DCF18E1 00000EB6A853 05F64A.1.FFFF 09E 061F39.1.005A 07949F ----- ------ 00002610 11111111
002C 00000DCF18E2 00000EB6A854 05F64A.1.FFFF 0A0 061F39.1.005B 07A1F9 ----- ------ 00002610 11111111
002D 00000EBCB411 00000EB6A684 0612D3.1.FFFF 104 061F37.1.0015 025989 ----- ------ 00042000 11111111
002E 00000EBCB413 00000EB6A688 0612D3.1.FFFF 106 061F37.1.0019 028EB1 ----- ------ 00042000 11111111
002F 00000EBCB414 00000EB6A689 0612D3.1.FFFF 107 061F37.1.001A 029C0B ----- ------ 00042000 11111111
0030 00000EBCB41F 00000EB6A68A 0612D3.1.FFFF 110 061F37.1.001B 02A965 ----- ------ 00042000 11111111
0031 00000EBCB420 00000EB6A68B 0612D3.1.FFFF 111 061F37.1.001C 02B6BF ----- ------ 00042000 11111111
0032 00000EBCB421 00000EB6A68C 0612D3.1.FFFF 112 061F37.1.001D 02C419 ----- ------ 00042000 11111111
0033 00000EBCB42E 00000EB6A68D 0612D3.1.FFFF 11E 061F37.1.001E 02D173 ----- ------ 00042000 11111111
0034 00000EBCB42F 00000EB6A836 0612D3.1.FFFF 11F 061F39.1.003D 061227 ----- ------ 00002600 11111111
0035 00000EBCB430 00000EB6A837 0612D3.1.FFFF 11F 061F39.1.003E 061F81 ----- ------ 00002610 11111111
0036 00000EBCB431 00000EB6A838 0612D3.1.FFFF 120 061F39.1.003F 062CDB ----- ------ 00002600 11111111
0037 00000EBCB432 00000EB6A839 0612D3.1.FFFF 121 061F39.1.0040 063A3B ----- ------ 00002610 11111111
0038 00000EBCB43B 00000EB6A68E 0612D3.1.FFFF 129 061F37.1.001F 02DECD ----- ------ 00042000 11111111
0039 00000EBCB43C 00000EB6A68F 0612D3.1.FFFF 12A 061F37.1.0020 02EC2D ----- ------ 00042000 11111111
003A 00000EBCB456 00000EB6A690 0612D3.1.FFFF 141 061F37.1.0021 02F947 ----- ------ 00042000 11111111
003B 00000EBCB4E9 00000EB6A691 0612D3.1.FFFF 04D 061F37.1.0022 0306A1 ----- ------ 00042000 11111111
003C 00000EBCB4F6 00000EB6A692 0612D3.1.FFFF 058 061F37.1.0023 0313FB ----- ------ 00042000 11111111
003D 00000EBCB4F7 00000EB6A693 0612D3.1.FFFF 059 061F37.1.0024 032155 ----- ------ 00042000 11111111
003E 00000EBCB504 00000EB6A694 0612D3.1.FFFF 065 061F37.1.0025 032EAF ----- ------ 00042000 11111111
003F 00000EBCB505 00000EB6A695 0612D3.1.FFFF 066 061F37.1.0026 033C09 ----- ------ 00042000 11111111
0040 00000EBCB511 00000EB6A696 0612D3.1.FFFF 070 061F37.1.0027 034963 ----- ------ 00042000 11111111
0041 00000EBCB512 00000EB6A697 0612D3.1.FFFF 071 061F37.1.0028 0356BD ----- ------ 00042000 11111111
0042 00000EBCB513 00000EB6A698 0612D3.1.FFFF 072 061F37.1.0029 036417 ----- ------ 00042000 11111111
0043 00000EBCB514 00000EB6A699 0612D3.1.FFFF 073 061F37.1.002A 037171 ----- ------ 00042000 11111111
0044 00000EBCB51F 00000EB6A69A 0612D3.1.FFFF 07C 061F37.1.002B 037E8B ----- ------ 00042000 11111111
0045 00000EBCB520 00000EB6A69B 0612D3.1.FFFF 07D 061F37.1.002C 038BE5 ----- ------ 00042000 11111111
0046 00000EBCB521 00000EB6A69C 0612D3.1.FFFF 07E 061F37.1.002D 03993F ----- ------ 00042000 11111111
0047 00000EBCB548 00000EB6A69D 0612D4.1.FFFF 0BF 061F37.1.002E 03A699 ----- ------ 00042000 11111111
0048 00000EBCB55A 00000EB6A69E 0612D4.1.FFFF 0CF 061F37.1.002F 03B3F3 ----- ------ 00042000 11111111
0049 00000EBCB55B 00000EB6A69F 0612D4.1.FFFF 0D0 061F37.1.0030 03C14D ----- ------ 00042000 11111111
004A 00000EBCB55C 00000EB6A6A0 0612D4.1.FFFF 0D1 061F37.1.0031 03CEA7 ----- ------ 00042000 11111111
004B 00000EBCB55D 00000EB6A6A1 0612D4.1.FFFF 0D2 061F37.1.0032 03DC01 ----- ------ 00042000 11111111
004C 00000EBCB55E 00000EB6A6A2 0612D4.1.FFFF 0D2 061F37.1.0033 03E95B ----- ------ 00042000 11111111
004D 00000EBCB567 00000EB6A6A3 0612D4.1.FFFF 0DA 061F37.1.0034 03F6B5 ----- ------ 00042000 11111111
004E 00000EBCB568 00000EB6A6A4 0612D4.1.FFFF 0DB 061F37.1.0035 04040F ----- ------ 00042000 11111111
004F 00000EBCB569 00000EB6A6A5 0612D4.1.FFFF 0DC 061F37.1.0036 041129 ----- ------ 00042000 11111111
0050 00000EBCB56A 00000EB6A6A6 0612D4.1.FFFF 0DD 061F37.1.0037 041E83 ----- ------ 00042000 11111111
0051 00000EBCB56B 00000EB6A6A7 0612D4.1.FFFF 0DE 061F37.1.0038 042BDD ----- ------ 00042000 11111111
0052 00000EBCB576 00000EB6A6A8 0612D4.1.FFFF 0E8 061F37.1.0039 043937 ----- ------ 00042000 11111111
0053 00000EBCB577 00000EB6A6A9 0612D4.1.FFFF 0E9 061F37.1.003A 044691 ----- ------ 00042000 11111111
0054 00000EBCB578 00000EB6A6AA 0612D4.1.FFFF 0E9 061F37.1.003B 0453EB ----- ------ 00042000 11111111
0055 00000EBCB583 00000EB6A6AB 0612D4.1.FFFF 0F3 061F37.1.003C 046145 ----- ------ 00042000 11111111
0056 00000EBCB584 00000EB6A6AC 0612D4.1.FFFF 0F4 061F37.1.003D 046E9F ----- ------ 00042000 11111111
0057 00000EBCB585 00000EB6A6AD 0612D4.1.FFFF 0F5 061F37.1.003E 047BF9 ----- ------ 00042000 11111111
0058 00000EBCB586 00000EB6A6AE 0612D4.1.FFFF 0F6 061F37.1.003F 048953 ----- ------ 00042000 11111111
0059 00000EBCB590 00000EB6A6AF 0612D4.1.FFFF 0FF 061F37.1.0040 0496B3 ----- ------ 00042000 11111111
005A 00000EBCB591 00000EB6A6B0 0612D4.1.FFFF 100 061F37.1.0041 04A3CD ----- ------ 00042000 11111111
005B 00000EBCB592 00000EB6A6B1 0612D4.1.FFFF 100 061F37.1.0042 04B127 ----- ------ 00042000 11111111
005C 00000EBCB593 00000EB6A6B2 0612D4.1.FFFF 101 061F37.1.0043 04BE81 ----- ------ 00042000 11111111
005D 00000EBCB59E 00000EB6A6B3 0612D4.1.FFFF 10B 061F37.1.0044 04CBDB ----- ------ 00042000 11111111
005E 00000EBCB59F 00000EB6A6B4 0612D4.1.FFFF 10C 061F37.1.0045 04D935 ----- ------ 00042000 11111111
005F 00000EBCB5A0 00000EB6A6B5 0612D4.1.FFFF 10D 061F37.1.0046 04E68F ----- ------ 00042000 11111111
0060 00000EBCB5A1 00000EB6A6B6 0612D4.1.FFFF 10E 061F37.1.0047 04F3E9 ----- ------ 00042000 11111111
0061 00000EBCB5AC 00000EB6A6B7 0612D4.1.FFFF 117 061F37.1.0048 050143 ----- ------ 00042000 11111111
0062 00000EBCB5AD 00000EB6A6B8 0612D4.1.FFFF 118 061F37.1.0049 050E9D ----- ------ 00042000 11111111
0063 00000EBCB5AE 00000EB6A6B9 0612D4.1.FFFF 119 061F37.1.004A 051BF7 ----- ------ 00042000 11111111
0064 00000EBCB5AF 00000EB6A6BA 0612D4.1.FFFF 11A 061F37.1.004B 052911 ----- ------ 00042000 11111111
0065 00000EBCB5B7 00000EB6A6BB 0612D4.1.FFFF 123 061F37.1.004C 05366B ----- ------ 00042000 11111111
0066 00000EBCB5B8 00000EB6A6BC 0612D4.1.FFFF 124 061F37.1.004D 0543C5 ----- ------ 00042000 11111111
0067 00000EBCB5B9 00000EB6A6BD 0612D4.1.FFFF 125 061F37.1.004E 05511F ----- ------ 00042000 11111111
0068 00000EBCB5BA 00000EB6A6BE 0612D4.1.FFFF 126 061F37.1.004F 055E79 ----- ------ 00042000 11111111
0069 00000EBCB5C5 00000EB6A6BF 0612D4.1.FFFF 12F 061F37.1.0050 056BD3 ----- ------ 00042000 11111111
006A 00000EBCB5C6 00000EB6A6C0 0612D4.1.FFFF 130 061F37.1.0051 05792D ----- ------ 00042000 11111111
006B 00000EBCB5C7 00000EB6A6C1 0612D4.1.FFFF 131 061F37.1.0052 058687 ----- ------ 00042000 11111111
006C 00000EBCB5D3 00000EB6A6C2 0612D4.1.FFFF 13C 061F37.1.0053 0593E1 ----- ------ 00042000 11111111
006D 00000EBCB5D4 00000EB6A6C3 0612D4.1.FFFF 13D 061F37.1.0054 05A13B ----- ------ 00042000 11111111
006E 00000EBCB5E0 00000EB6A6C4 0612D4.1.FFFF 147 061F37.1.0055 05AE95 ----- ------ 00042000 11111111
006F 00000EBCB5E1 00000EB6A6C5 0612D4.1.FFFF 148 061F37.1.0056 05BBAF ----- ------ 00042000 11111111
0070 00000EBCB5EE 00000EB6A6C6 0612D4.1.FFFF 154 061F37.1.0057 05C909 ----- ------ 00042000 11111111
0071 00000EBCB632 00000EB6A6C7 0612D4.1.FFFF 018 061F37.1.0058 05D663 ----- ------ 00042000 11111111
0072 00000EBCB63E 00000EB6A6C8 0612D4.1.FFFF 022 061F37.1.0059 05E3BD ----- ------ 00042000 11111111
0073 00000EBCB63F 00000EB6A6C9 0612D4.1.FFFF 023 061F37.1.005A 05F117 ----- ------ 00042000 11111111
0074 00000EBCB64C 00000EB6A6CA 0612D4.1.FFFF 02F 061F37.1.005B 05FE71 ----- ------ 00042000 11111111
0075 00000EBCB64D 00000EB6A6CB 0612D4.1.FFFF 030 061F37.1.005C 060BCB ----- ------ 00042000 11111111
0076 00000EBCB64E 00000EB6A82F 0612D4.1.FFFF 030 061F39.1.0036 05B4B1 ----- ------ 00002600 11111111
0077 00000EBCB64F 00000EB6A830 0612D4.1.FFFF 031 061F39.1.0037 05C20B ----- ------ 00002610 11111111
0078 00000EBCB650 00000EB6A831 0612D4.1.FFFF 032 061F39.1.0038 05CF65 ----- ------ 00002600 11111111
0079 00000EBCB651 00000EB6A832 0612D4.1.FFFF 033 061F39.1.0039 05DCBF ----- ------ 00002610 11111111
007A 00000EBCB652 00000EB6A833 0612D4.1.FFFF 034 061F39.1.003A 05EA19 ----- ------ 00002600 11111111
007B 00000EBCB653 00000EB6A834 0612D4.1.FFFF 035 061F39.1.003B 05F773 ----- ------ 00002610 11111111
007C 00000EBCB65A 00000EB6A6CC 0612D4.1.FFFF 03B 061F37.1.005D 061925 ----- ------ 00042000 11111111
007D 00000EBCB667 00000EB6A6CD 0612D4.1.FFFF 046 061F37.1.005E 06267F ----- ------ 00042000 11111111
007E 00000EBCB676 00000EB6A6CE 0612D4.1.FFFF 054 061F37.1.005F 0633D9 ----- ------ 00042000 11111111
007F 00000EBCB682 00000EB6A6CF 0612D4.1.FFFF 05E 061F37.1.0060 064139 ----- ------ 00042000 11111111
0080 00000EBCB68F 00000EB6A6D0 0612D4.1.FFFF 06C 061F37.1.0061 064E53 ----- ------ 00042000 11111111
0081 00000EBCB690 00000EB6A6D1 0612D4.1.FFFF 06D 061F37.1.0062 065BAD ----- ------ 00042000 11111111
0082 00000EBCB691 00000EB6A6D2 0612D4.1.FFFF 06D 061F37.1.0063 066907 ----- ------ 00042000 11111111
0083 00000EBCB69C 00000EB6A6D3 0612D4.1.FFFF 077 061F37.1.0064 067661 ----- ------ 00042000 11111111
0084 00000EBCB69D 00000EB6A6D4 0612D4.1.FFFF 078 061F37.1.0065 0683BB ----- ------ 00042000 11111111
0085 00000EBCB69E 00000EB6A6D5 0612D4.1.FFFF 079 061F37.1.0066 069115 ----- ------ 00042000 11111111
0086 00000EBCB6AE 00000EB6A6D6 0612D4.1.FFFF 087 061F37.1.0067 069E6F ----- ------ 00042000 11111111
0087 00000EBCB6AF 00000EB6A6D7 0612D4.1.FFFF 088 061F37.1.0068 06ABC9 ----- ------ 00042000 11111111
0088 00000EBCB6B0 00000EB6A6D8 0612D4.1.FFFF 089 061F37.1.0069 06B923 ----- ------ 00042000 11111111
0089 00000EBCB6B1 00000EB6A6D9 0612D4.1.FFFF 08A 061F37.1.006A 06C67D ----- ------ 00042000 11111111
008A 00000EBCB6C7 00000EB6A6DA 0612D4.1.FFFF 09D 061F37.1.006B 06D397 ----- ------ 00042000 11111111
008B 00000EBCB6D2 00000EB6A835 0612D4.1.FFFF 0A7 061F39.1.003C 0604CD ----- ------ 00002300 11111111
008C 00000EBCB6D3 00000EB6A6DC 0612D4.1.FFFF 0A8 061F37.1.006D 06EE4B ----- ------ 00042000 11111111
008D 00000EBCB6D4 00000EB6A6DD 0612D4.1.FFFF 0A9 061F37.1.006E 06FBA5 ----- ------ 00042000 11111111
008E 00000EBCB6D5 00000EB6A6DE 0612D4.1.FFFF 0AA 061F37.1.006F 0708FF ----- ------ 00042000 11111111
008F 00000EBCB700 00000EB6A6DF 0612D5.1.FFFF 0EE 061F37.1.0070 071659 ----- ------ 00042000 11111111
0090 00000EBCB701 00000EB6A6E0 0612D5.1.FFFF 0EF 061F37.1.0071 0723B3 ----- ------ 00042000 11111111
0091 00000EBCB702 00000EB6A6E1 0612D5.1.FFFF 0F0 061F37.1.0072 07310D ----- ------ 00042000 11111111
0092 00000EBCB70E 00000EB6A6E2 0612D5.1.FFFF 0FA 061F37.1.0073 073E67 ----- ------ 00042000 11111111
0093 00000EBCB70F 00000EB6A6E3 0612D5.1.FFFF 0FB 061F37.1.0074 074BC1 ----- ------ 00042000 11111111
0094 00000EBCB71B 00000EB6A6E4 0612D5.1.FFFF 106 061F37.1.0075 07591B ----- ------ 00042000 11111111
0095 00000EBCB71C 00000EB6A6E5 0612D5.1.FFFF 107 061F37.1.0076 076635 ----- ------ 00042000 11111111
0096 00000EBCB71D 00000EB6A6E6 0612D5.1.FFFF 107 061F37.1.0077 07738F ----- ------ 00042000 11111111
0097 00000EBCB71E 00000EB6A6E7 0612D5.1.FFFF 108 061F37.1.0078 0780E9 ----- ------ 00042000 11111111
0098 00000EBCB729 00000EB6A6E8 0612D5.1.FFFF 112 061F37.1.0079 078E43 ----- ------ 00042000 11111111
0099 00000EBCB72A 00000EB6A6E9 0612D5.1.FFFF 113 061F37.1.007A 079B9D ----- ------ 00042000 11111111
009A 00000EBCB72B 00000EB6A6EA 0612D5.1.FFFF 114 061F37.1.007B 07A8F7 ----- ------ 00042000 11111111
009B 00000EBCB736 00000EB6A6EB 0612D5.1.FFFF 11E 061F37.1.007C 07B651 ----- ------ 00042000 11111111
009C 00000EBCB737 00000EB6A6EC 0612D5.1.FFFF 11E 061F37.1.007D 07C3AB ----- ------ 00042000 11111111
009D 00000EBCB738 00000EB6A6ED 0612D5.1.FFFF 11F 061F37.1.007E 07D105 ----- ------ 00042000 11111111
009E 00000EBCB739 00000EB6A6EE 0612D5.1.FFFF 120 061F37.1.007F 07DE5F ----- ------ 00042000 11111111
009F 00000EBCB743 00000EB6A6EF 0612D5.1.FFFF 129 061F37.1.0080 07EBBF ----- ------ 00042000 11111111
00A0 00000EBCB744 00000EB6A6F0 0612D5.1.FFFF 12A 061F37.1.0081 07F8D9 ----- ------ 00042000 11111111
00A1 00000EBCB745 00000EB6A6F1 0612D5.1.FFFF 12B 061F37.1.0082 080633 ----- ------ 00042000 11111111
00A2 00000EBCB746 00000EB6A6F2 0612D5.1.FFFF 12C 061F37.1.0083 08138D ----- ------ 00042000 11111111
00A3 00000EBCB751 00000EB6A6F3 0612D5.1.FFFF 135 061F37.1.0084 0820E7 ----- ------ 00042000 11111111
00A4 00000EBCB752 00000EB6A6F4 0612D5.1.FFFF 136 061F37.1.0085 082E41 ----- ------ 00042000 11111111
00A5 00000EBCB753 00000EB6A6F5 0612D5.1.FFFF 137 061F37.1.0086 083B9B ----- ------ 00042000 11111111
00A6 00000EBCB754 00000EB6A6F6 0612D5.1.FFFF 138 061F37.1.0087 0848F5 ----- ------ 00042000 11111111
00A7 00000EBCB75C 00000EB6A6F7 0612D5.1.FFFF 141 061F37.1.0088 08564F ----- ------ 00042000 11111111
00A8 00000EBCB75D 00000EB6A6F8 0612D5.1.FFFF 142 061F37.1.0089 0863A9 ----- ------ 00042000 11111111
00A9 00000EBCB75E 00000EB6A6F9 0612D5.1.FFFF 143 061F37.1.008A 087103 ----- ------ 00042000 11111111
00AA 00000EBCB75F 00000EB6A6FA 0612D5.1.FFFF 144 061F37.1.008B 087E1D ----- ------ 00042000 11111111
00AB 00000EBCB76B 00000EB6A6FB 0612D5.1.FFFF 14E 061F37.1.008C 088B77 ----- ------ 00042000 11111111
00AC 00000EBCB76C 00000EB6A6FC 0612D5.1.FFFF 14F 061F37.1.008D 0898D1 ----- ------ 00042000 11111111
00AD 00000EBCB778 00000EB6A6FD 0612D5.1.FFFF 15A 061F37.1.008E 08A62B ----- ------ 00042000 11111111
00AE 00000EBCB779 00000EB6A6FE 0612D5.1.FFFF 15B 061F37.1.008F 08B385 ----- ------ 00042000 11111111
00AF 00000EBCB793 00000EB6A6FF 0612D5.1.FFFF 172 061F37.1.0090 08C0DF ----- ------ 00042000 11111111
00B0 00000EBCB7A0 00000EB6A700 0612D5.1.FFFF 005 061F37.1.0091 08CE39 ----- ------ 00042000 11111111
00B1 00000EBCB7A1 00000EB6A701 0612D5.1.FFFF 006 061F37.1.0092 08DB93 ----- ------ 00042000 11111111
00B2 00000EBCB7AD 00000EB6A702 0612D5.1.FFFF 010 061F37.1.0093 08E8ED ----- ------ 00042000 11111111
00B3 00000EBCB7AE 00000EB6A703 0612D5.1.FFFF 011 061F37.1.0094 08F647 ----- ------ 00042000 11111111
00B4 00000EBCB7BA 00000EB6A704 0612D5.1.FFFF 01C 061F37.1.0095 0903A1 ----- ------ 00042000 11111111
00B5 00000EBCB7BB 00000EB6A705 0612D5.1.FFFF 01D 061F37.1.0096 0910BB ----- ------ 00042000 11111111
00B6 00000EBCB7BC 00000EB6A706 0612D5.1.FFFF 01E 061F37.1.0097 091E15 ----- ------ 00042000 11111111
00B7 00000EBCB7BD 00000EB6A707 0612D5.1.FFFF 01F 061F37.1.0098 092B6F ----- ------ 00042000 11111111
00B8 00000EBCB7C9 00000EB6A708 0612D5.1.FFFF 029 061F37.1.0099 0938C9 ----- ------ 00042000 11111111
00B9 00000EBCB7CA 00000EB6A709 0612D5.1.FFFF 02A 061F37.1.009A 094623 ----- ------ 00042000 11111111
00BA 00000EBCB7D7 00000EB6A70A 0612D5.1.FFFF 036 061F37.1.009B 09537D ----- ------ 00042000 11111111
00BB 00000EBCB7E4 00000EB6A70B 0612D5.1.FFFF 041 061F37.1.009C 0960D7 ----- ------ 00042000 11111111
00BC 00000EBCB7E5 00000EB6A70C 0612D5.1.FFFF 042 061F37.1.009D 096E31 ----- ------ 00042000 11111111
00BD 00000EBCB7F1 00000EB6A70D 0612D5.1.FFFF 04D 061F37.1.009E 097B8B ----- ------ 00042000 11111111
00BE 00000EBCB7F2 00000EB6A70E 0612D5.1.FFFF 04E 061F37.1.009F 0988E5 ----- ------ 00042000 11111111
00BF 00000EBCB7FE 00000EB6A70F 0612D5.1.FFFF 058 061F37.1.00A0 099645 ----- ------ 00042000 11111111
00C0 00000EBCB7FF 00000EB6A710 0612D5.1.FFFF 059 061F37.1.00A1 09A35F ----- ------ 00042000 11111111
00C1 00000EBCB800 00000EB6A711 0612D5.1.FFFF 05A 061F37.1.00A2 09B0B9 ----- ------ 00042000 11111111
00C2 00000EBCB801 00000EB6A712 0612D5.1.FFFF 05B 061F37.1.00A3 09BE13 ----- ------ 00042000 11111111
00C3 00000EBCB802 00000EB6A713 0612D5.1.FFFF 05C 061F37.1.00A4 09CB6D ----- ------ 00042000 11111111
00C4 00000EBCB80C 00000EB6A714 0612D5.1.FFFF 064 061F37.1.00A5 09D8C7 ----- ------ 00042000 11111111
00C5 00000EBCB80D 00000EB6A715 0612D5.1.FFFF 065 061F37.1.00A6 09E621 ----- ------ 00042000 11111111
00C6 00000EBCB80E 00000EB6A716 0612D5.1.FFFF 066 061F37.1.00A7 09F37B ----- ------ 00042000 11111111
00C7 00000EBCB80F 00000EB6A717 0612D5.1.FFFF 067 061F37.1.00A8 0A00D5 ----- ------ 00042000 11111111
00C8 00000EBCB810 00000EB6A718 0612D5.1.FFFF 068 061F37.1.00A9 0A0E2F ----- ------ 00042000 11111111
00C9 00000EBCB81A 00000EB6A719 0612D5.1.FFFF 071 061F37.1.00AA 0A1B89 ----- ------ 00042000 11111111
00CA 00000EBCB81B 00000EB6A71A 0612D5.1.FFFF 072 061F37.1.00AB 0A28A3 ----- ------ 00042000 11111111
00CB 00000EBCB81C 00000EB6A71B 0612D5.1.FFFF 073 061F37.1.00AC 0A35FD ----- ------ 00042000 11111111
00CC 00000EBCB81D 00000EB6A71C 0612D5.1.FFFF 074 061F37.1.00AD 0A4357 ----- ------ 00042000 11111111
00CD 00000EBCB84E 00000EB6A71D 0612D5.1.FFFF 0A1 061F37.1.00AE 000BA1 ----- ------ 00042000 11111111
00CE 00000EBCB84F 00000EB6A71E 0612D5.1.FFFF 0A2 061F37.1.00AF 0018FB ----- ------ 00042000 11111111
00CF 00000EBCB850 00000EB6A71F 0612D5.1.FFFF 0A2 061F37.1.00B0 002655 ----- ------ 00042000 11111111
00D0 00000EBCB851 00000EB6A720 0612D5.1.FFFF 0A3 061F37.1.00B1 0033AF ----- ------ 00042000 11111111
00D1 00000EBCB85C 00000EB6A721 0612D5.1.FFFF 0AD 061F37.1.00B2 004109 ----- ------ 00042000 11111111
00D2 00000EBCB85D 00000EB6A722 0612D5.1.FFFF 0AE 061F37.1.00B3 004E63 ----- ------ 00042000 11111111
00D3 00000EBCB85E 00000EB6A723 0612D5.1.FFFF 0AF 061F37.1.00B4 005BBD ----- ------ 00042000 11111111
00D4 00000EBCB868 00000EB6A724 0612D5.1.FFFF 0B8 061F37.1.00B5 006917 ----- ------ 00042000 11111111
00D5 00000EBCB869 00000EB6A725 0612D5.1.FFFF 0B8 061F37.1.00B6 007631 ----- ------ 00042000 11111111
00D6 00000EBCB86A 00000EB6A726 0612D5.1.FFFF 0B9 061F37.1.00B7 00838B ----- ------ 00042000 11111111
00D7 00000EBCB86B 00000EB6A727 0612D5.1.FFFF 0BA 061F37.1.00B8 0090E5 ----- ------ 00042000 11111111
00D8 00000EBCB875 00000EB6A728 0612D5.1.FFFF 0C3 061F37.1.00B9 009E3F ----- ------ 00042000 11111111
00D9 00000EBCB876 00000EB6A729 0612D5.1.FFFF 0C4 061F37.1.00BA 00AB99 ----- ------ 00042000 11111111
00DA 00000EBCB877 00000EB6A72A 0612D5.1.FFFF 0C5 061F37.1.00BB 00B8F3 ----- ------ 00042000 11111111
00DB 00000EBCB878 00000EB6A72B 0612D5.1.FFFF 0C6 061F37.1.00BC 00C64D ----- ------ 00042000 11111111
00DC 00000EBCB879 00000EB6A72C 0612D5.1.FFFF 0C7 061F37.1.00BD 00D3A7 ----- ------ 00042000 11111111
00DD 00000EBCB8A4 00000EB6A72D 0612D6.1.FFFF 10B 061F37.1.00BE 00E101 ----- ------ 00042000 11111111
00DE 00000EBCB8A5 00000EB6A72E 0612D6.1.FFFF 10C 061F37.1.00BF 00EE5B ----- ------ 00042000 11111111
00DF 00000EBCB8A6 00000EB6A72F 0612D6.1.FFFF 10D 061F37.1.00C0 00FBBB ----- ------ 00042000 11111111
00E0 00000EBCB8A7 00000EB6A730 0612D6.1.FFFF 10E 061F37.1.00C1 0108D5 ----- ------ 00042000 11111111
00E1 00000EBCB8B1 00000EB6A731 0612D6.1.FFFF 116 061F37.1.00C2 01162F ----- ------ 00042000 11111111
00E2 00000EBCB8B2 00000EB6A732 0612D6.1.FFFF 117 061F37.1.00C3 012389 ----- ------ 00042000 11111111
00E3 00000EBCB8B3 00000EB6A733 0612D6.1.FFFF 118 061F37.1.00C4 0130E3 ----- ------ 00042000 11111111
00E4 00000EBCB8B4 00000EB6A734 0612D6.1.FFFF 119 061F38.1.0000 02136B ----- ------ 00000122 00000000
00E5 00000EBCB8BF 00000EB6A735 0612D6.1.FFFF 123 061F38.1.0001 022085 ----- ------ 00042000 11111111
00E6 00000EBCB8C0 00000EB6A736 0612D6.1.FFFF 124 061F38.1.0002 022DDF ----- ------ 00042000 11111111
00E7 00000EBCB8C1 00000EB6A737 0612D6.1.FFFF 125 061F38.1.0003 023B39 ----- ------ 00042000 11111111
00E8 00000EBCB8C2 00000EB6A738 0612D6.1.FFFF 125 061F38.1.0004 024893 ----- ------ 00042000 11111111
00E9 00000EBCB8C3 00000EB6A739 0612D6.1.FFFF 126 061F38.1.0005 0255ED ----- ------ 00042000 11111111
00EA 00000EBCB8CD 00000EB6A73A 0612D6.1.FFFF 12F 061F38.1.0006 026347 ----- ------ 00042000 11111111
00EB 00000EBCB8CE 00000EB6A73B 0612D6.1.FFFF 130 061F38.1.0007 0270A1 ----- ------ 00042000 11111111
00EC 00000EBCB8CF 00000EB6A73D 0612D6.1.FFFF 131 061F38.1.0009 028B55 ----- ------ 00042000 11111111
00ED 00000EBCB8DA 00000EB6A73E 0612D6.1.FFFF 13B 061F38.1.000A 0298AF ----- ------ 00042000 11111111
00EE 00000EBCB8DB 00000EB6A73F 0612D6.1.FFFF 13C 061F38.1.000B 02A5C9 ----- ------ 00042000 11111111
00EF 00000EBCB8DC 00000EB6A740 0612D6.1.FFFF 13C 061F38.1.000C 02B323 ----- ------ 00042000 11111111
00F0 00000EBCB8DD 00000EB6A741 0612D6.1.FFFF 13D 061F38.1.000D 02C07D ----- ------ 00042000 11111111
00F1 00000EBCB8E8 00000EB6A742 0612D6.1.FFFF 147 061F38.1.000E 02CDD7 ----- ------ 00042000 11111111
00F2 00000EBCB8E9 00000EB6A743 0612D6.1.FFFF 148 061F38.1.000F 02DB31 ----- ------ 00042000 11111111
00F3 00000EBCB8EA 00000EB6A744 0612D6.1.FFFF 149 061F38.1.0010 02E88B ----- ------ 00042000 11111111
00F4 00000EBCB8EB 00000EB6A745 0612D6.1.FFFF 14A 061F38.1.0011 02F5E5 ----- ------ 00042000 11111111
00F5 00000EBCB8F7 00000EB6A746 0612D6.1.FFFF 154 061F38.1.0012 03033F ----- ------ 00042000 11111111
00F6 00000EBCB8F8 00000EB6A747 0612D6.1.FFFF 155 061F38.1.0013 031099 ----- ------ 00042000 11111111
00F7 00000EBCB902 00000EB6A748 0612D6.1.FFFF 160 061F38.1.0014 031DF3 ----- ------ 00042000 11111111
00F8 00000EBCB903 00000EB6A749 0612D6.1.FFFF 161 061F38.1.0015 032B4D ----- ------ 00042000 11111111
00F9 00000EBCB910 00000EB6A74A 0612D6.1.FFFF 16C 061F38.1.0016 033867 ----- ------ 00042000 11111111
00FA 00000EBCB91D 00000EB6A74B 0612D6.1.FFFF 000 061F38.1.0017 0345C1 ----- ------ 00042000 11111111
00FB 00000EBCB92A 00000EB6A74C 0612D6.1.FFFF 00B 061F38.1.0018 03531B ----- ------ 00042000 11111111
00FC 00000EBCB92B 00000EB6A74D 0612D6.1.FFFF 00C 061F38.1.0019 036075 ----- ------ 00042000 11111111
00FD 00000EBCB945 00000EB6A74E 0612D6.1.FFFF 023 061F38.1.001A 036DCF ----- ------ 00042000 11111111
00FE 00000EBCB952 00000EB6A74F 0612D6.1.FFFF 02E 061F38.1.001B 037B29 ----- ------ 00042000 11111111
00FF 00000EBCB960 00000EB6A750 0612D6.1.FFFF 03B 061F38.1.001C 038883 ----- ------ 00042000 11111111
0100 00000EBCB961 00000EB6A751 0612D6.1.FFFF 03C 061F38.1.001D 0395DD ----- ------ 00042000 11111111
0101 00000EBCB96C 00000EB6A752 0612D6.1.FFFF 045 061F38.1.001E 03A337 ----- ------ 00042000 11111111
0102 00000EBCB96D 00000EB6A753 0612D6.1.FFFF 046 061F38.1.001F 03B091 ----- ------ 00042000 11111111
0103 00000EBCB96E 00000EB6A754 0612D6.1.FFFF 047 061F38.1.0020 03BDF1 ----- ------ 00042000 11111111
0104 00000EBCB96F 00000EB6A755 0612D6.1.FFFF 048 061F38.1.0021 03CB0B ----- ------ 00042000 11111111
0105 00000EBCB97B 00000EB6A756 0612D6.1.FFFF 053 061F38.1.0022 03D865 ----- ------ 00042000 11111111
0106 00000EBCB97C 00000EB6A757 0612D6.1.FFFF 054 061F38.1.0023 03E5BF ----- ------ 00042000 11111111
0107 00000EBCB988 00000EB6A758 0612D6.1.FFFF 05E 061F38.1.0024 03F319 ----- ------ 00042000 11111111
0108 00000EBCB989 00000EB6A759 0612D6.1.FFFF 05F 061F38.1.0025 040073 ----- ------ 00042000 11111111
0109 00000EBCB98A 00000EB6A75A 0612D6.1.FFFF 060 061F38.1.0026 040DCD ----- ------ 00042000 11111111
010A 00000EBCB98B 00000EB6A75B 0612D6.1.FFFF 061 061F38.1.0027 041B27 ----- ------ 00042000 11111111
010B 00000EBCB98C 00000EB6A75C 0612D6.1.FFFF 062 061F38.1.0028 042881 ----- ------ 00042000 11111111
010C 00000EBCB996 00000EB6A75D 0612D6.1.FFFF 06B 061F38.1.0029 0435DB ----- ------ 00042000 11111111
010D 00000EBCB997 00000EB6A75E 0612D6.1.FFFF 06C 061F38.1.002A 044335 ----- ------ 00042000 11111111
010E 00000EBCB998 00000EB6A75F 0612D6.1.FFFF 06C 061F38.1.002B 04504F ----- ------ 00042000 11111111
010F 00000EBCB999 00000EB6A760 0612D6.1.FFFF 06D 061F38.1.002C 045DA9 ----- ------ 00042000 11111111
0110 00000EBCB99A 00000EB6A761 0612D6.1.FFFF 06E 061F38.1.002D 046B03 ----- ------ 00042000 11111111
0111 00000EBCB9BD 00000EB6A762 0612D6.1.FFFF 08D 061F38.1.002E 04785D ----- ------ 00042000 11111111
0112 00000EBCB9BE 00000EB6A763 0612D6.1.FFFF 08E 061F38.1.002F 0485B7 ----- ------ 00042000 11111111
0113 00000EBCB9BF 00000EB6A764 0612D6.1.FFFF 08F 061F38.1.0030 049311 ----- ------ 00042000 11111111
0114 00000EBCB9C0 00000EB6A765 0612D6.1.FFFF 090 061F38.1.0031 04A06B ----- ------ 00042000 11111111
0115 00000EBCB9C1 00000EB6A766 0612D6.1.FFFF 091 061F38.1.0032 04ADC5 ----- ------ 00042000 11111111
0116 00000EBCB9CB 00000EB6A767 0612D6.1.FFFF 09B 061F38.1.0033 04BB1F ----- ------ 00042000 11111111
0117 00000EBCB9CC 00000EB6A768 0612D6.1.FFFF 09C 061F38.1.0034 04C879 ----- ------ 00042000 11111111
0118 00000EBCB9CD 00000EB6A769 0612D6.1.FFFF 09D 061F38.1.0035 04D5D3 ----- ------ 00042000 11111111
0119 00000EBCB9D6 00000EB6A76A 0612D6.1.FFFF 0A5 061F38.1.0036 04E2ED ----- ------ 00042000 11111111
011A 00000EBCB9D7 00000EB6A76B 0612D6.1.FFFF 0A6 061F38.1.0037 04F047 ----- ------ 00042000 11111111
011B 00000EBCB9D8 00000EB6A76C 0612D6.1.FFFF 0A7 061F38.1.0038 04FDA1 ----- ------ 00042000 11111111
011C 00000EBCB9D9 00000EB6A76D 0612D6.1.FFFF 0A8 061F38.1.0039 050AFB ----- ------ 00042000 11111111
011D 00000EBCB9DA 00000EB6A76E 0612D6.1.FFFF 0A9 061F38.1.003A 051855 ----- ------ 00042000 11111111
011E 00000EBCB9E4 00000EB6A76F 0612D6.1.FFFF 0B1 061F38.1.003B 0525AF ----- ------ 00042000 11111111
011F 00000EBCB9E5 00000EB6A770 0612D6.1.FFFF 0B2 061F38.1.003C 053309 ----- ------ 00042000 11111111
0120 00000EBCB9E6 00000EB6A771 0612D6.1.FFFF 0B3 061F38.1.003D 054063 ----- ------ 00042000 11111111
0121 00000EBCB9E7 00000EB6A772 0612D6.1.FFFF 0B4 061F38.1.003E 054DBD ----- ------ 00042000 11111111
0122 00000EBCB9F1 00000EB6A773 0612D6.1.FFFF 0BD 061F38.1.003F 055B17 ----- ------ 00042000 11111111
0123 00000EBCB9F2 00000EB6A774 0612D6.1.FFFF 0BE 061F38.1.0040 056877 ----- ------ 00042000 11111111
0124 00000EBCB9F3 00000EB6A775 0612D6.1.FFFF 0BF 061F38.1.0041 057591 ----- ------ 00042000 11111111
0125 00000EBCB9F4 00000EB6A776 0612D6.1.FFFF 0C0 061F38.1.0042 0582EB ----- ------ 00042000 11111111
0126 00000EBCB9F5 00000EB6A777 0612D6.1.FFFF 0C0 061F38.1.0043 059045 ----- ------ 00042000 11111111
0127 00000EBCB9F6 00000EB6A778 0612D6.1.FFFF 0C1 061F38.1.0044 059D9F ----- ------ 00042000 11111111
0128 00000EBCB9FF 00000EB6A779 0612D6.1.FFFF 0C9 061F38.1.0045 05AAF9 ----- ------ 00042000 11111111
0129 00000EBCBA00 00000EB6A77A 0612D6.1.FFFF 0CA 061F38.1.0046 05B853 ----- ------ 00042000 11111111
012A 00000EBCBA01 00000EB6A77B 0612D6.1.FFFF 0CB 061F38.1.0047 05C5AD ----- ------ 00042000 11111111
012B 00000EBCBA02 00000EB6A77C 0612D6.1.FFFF 0CC 061F38.1.0048 05D307 ----- ------ 00042000 11111111
012C 00000EBCBA03 00000EB6A77D 0612D6.1.FFFF 0CD 061F38.1.0049 05E061 ----- ------ 00042000 11111111
012D 00000EBCBA0D 00000EB6A77E 0612D6.1.FFFF 0D6 061F38.1.004A 05EDBB ----- ------ 00042000 11111111
012E 00000EBCBA0E 00000EB6A77F 0612D6.1.FFFF 0D6 061F38.1.004B 05FAD5 ----- ------ 00042000 11111111
012F 00000EBCBA0F 00000EB6A780 0612D6.1.FFFF 0D7 061F38.1.004C 06082F ----- ------ 00042000 11111111
0130 00000EBCBA10 00000EB6A781 0612D6.1.FFFF 0D8 061F38.1.004D 061589 ----- ------ 00042000 11111111
0131 00000EBCBA1A 00000EB6A782 0612D6.1.FFFF 0E1 061F38.1.004E 0622E3 ----- ------ 00042000 11111111
0132 00000EBCBA1B 00000EB6A783 0612D6.1.FFFF 0E2 061F38.1.004F 06303D ----- ------ 00042000 11111111
0133 00000EBCBA1C 00000EB6A784 0612D6.1.FFFF 0E3 061F38.1.0050 063D97 ----- ------ 00042000 11111111
0134 00000EBCBA1D 00000EB6A785 0612D6.1.FFFF 0E4 061F38.1.0051 064AF1 ----- ------ 00042000 11111111
0135 00000EBCBA1E 00000EB6A786 0612D6.1.FFFF 0E5 061F38.1.0052 06584B ----- ------ 00042000 11111111
0136 00000EBCBA49 00000EB6A787 0612D7.1.FFFF 129 061F38.1.0053 0665A5 ----- ------ 00042000 11111111
0137 00000EBCBA4A 00000EB6A788 0612D7.1.FFFF 12A 061F38.1.0054 0672FF ----- ------ 00042000 11111111
0138 00000EBCBA4B 00000EB6A789 0612D7.1.FFFF 12B 061F38.1.0055 068059 ----- ------ 00042000 11111111
0139 00000EBCBA56 00000EB6A78A 0612D7.1.FFFF 134 061F38.1.0056 068D73 ----- ------ 00042000 11111111
013A 00000EBCBA57 00000EB6A78B 0612D7.1.FFFF 135 061F38.1.0057 069ACD ----- ------ 00042000 11111111
013B 00000EBCBA58 00000EB6A78C 0612D7.1.FFFF 136 061F38.1.0058 06A827 ----- ------ 00042000 11111111
013C 00000EBCBA59 00000EB6A78D 0612D7.1.FFFF 137 061F38.1.0059 06B581 ----- ------ 00042000 11111111
013D 00000EBCBA63 00000EB6A78E 0612D7.1.FFFF 140 061F38.1.005A 06C2DB ----- ------ 00042000 11111111
013E 00000EBCBA64 00000EB6A78F 0612D7.1.FFFF 141 061F38.1.005B 06D035 ----- ------ 00042000 11111111
013F 00000EBCBA65 00000EB6A790 0612D7.1.FFFF 142 061F38.1.005C 06DD8F ----- ------ 00042000 11111111
0140 00000EBCBA66 00000EB6A791 0612D7.1.FFFF 143 061F38.1.005D 06EAE9 ----- ------ 00042000 11111111
0141 00000EBCBA72 00000EB6A792 0612D7.1.FFFF 14D 061F38.1.005E 06F843 ----- ------ 00042000 11111111
0142 00000EBCBA73 00000EB6A793 0612D7.1.FFFF 14E 061F38.1.005F 07059D ----- ------ 00042000 11111111
0143 00000EBCBA80 00000EB6A794 0612D7.1.FFFF 15A 061F38.1.0060 0712FD ----- ------ 00042000 11111111
0144 00000EBCBACE 00000EB6A795 0612D7.1.FFFF 028 061F38.1.0061 072017 ----- ------ 00042000 11111111
0145 00000EBCBACF 00000EB6A796 0612D7.1.FFFF 029 061F38.1.0062 072D71 ----- ------ 00042000 11111111
0146 00000EBCBADC 00000EB6A797 0612D7.1.FFFF 035 061F38.1.0063 073ACB ----- ------ 00042000 11111111
0147 00000EBCBAE9 00000EB6A798 0612D7.1.FFFF 040 061F38.1.0064 074825 ----- ------ 00042000 11111111
0148 00000EBCBAEA 00000EB6A799 0612D7.1.FFFF 041 061F38.1.0065 07557F ----- ------ 00042000 11111111
0149 00000EBCBAF6 00000EB6A79A 0612D7.1.FFFF 04C 061F38.1.0066 0762D9 ----- ------ 00042000 11111111
014A 00000EBCBAF7 00000EB6A79B 0612D7.1.FFFF 04C 061F38.1.0067 077033 ----- ------ 00042000 11111111
014B 00000EBCBAF8 00000EB6A79C 0612D7.1.FFFF 04D 061F38.1.0068 077D8D ----- ------ 00042000 11111111
014C 00000EBCBB04 00000EB6A79D 0612D7.1.FFFF 058 061F38.1.0069 078AE7 ----- ------ 00042000 11111111
014D 00000EBCBB11 00000EB6A79E 0612D7.1.FFFF 063 061F38.1.006A 079841 ----- ------ 00042000 11111111
014E 00000EBCBB12 00000EB6A79F 0612D7.1.FFFF 064 061F38.1.006B 07A55B ----- ------ 00042000 11111111
014F 00000EBCBB13 00000EB6A7A0 0612D7.1.FFFF 065 061F38.1.006C 07B2B5 ----- ------ 00042000 11111111
0150 00000EBCBB14 00000EB6A7A1 0612D7.1.FFFF 066 061F38.1.006D 07C00F ----- ------ 00042000 11111111
0151 00000EBCBB22 00000EB6A7A2 0612D7.1.FFFF 073 061F38.1.006E 07CD69 ----- ------ 00042000 11111111
0152 00000EBCBB23 00000EB6A7A3 0612D7.1.FFFF 073 061F38.1.006F 07DAC3 ----- ------ 00042000 11111111
0153 00000EBCBB24 00000EB6A7A4 0612D7.1.FFFF 074 061F38.1.0070 07E81D ----- ------ 00042000 11111111
0154 00000EBCBB25 00000EB6A7A5 0612D7.1.FFFF 075 061F38.1.0071 07F577 ----- ------ 00042000 11111111
0155 00000EBCBB26 00000EB6A7A6 0612D7.1.FFFF 076 061F38.1.0072 0802D1 ----- ------ 00042000 11111111
0156 00000EBCBB33 00000EB6A7A7 0612D7.1.FFFF 082 061F38.1.0073 08102B ----- ------ 00042000 11111111
0157 00000EBCBB34 00000EB6A7A8 0612D7.1.FFFF 082 061F38.1.0074 081D85 ----- ------ 00042000 11111111
0158 00000EBCBB6F 00000EB6A7A9 0612D7.1.FFFF 0B8 061F38.1.0075 082ADF ----- ------ 00042000 11111111
0159 00000EBCBB70 00000EB6A7AA 0612D7.1.FFFF 0B9 061F38.1.0076 0837F9 ----- ------ 00042000 11111111
015A 00000EBCBB71 00000EB6A7AB 0612D7.1.FFFF 0BA 061F38.1.0077 084553 ----- ------ 00042000 11111111
015B 00000EBCBB72 00000EB6A7AC 0612D7.1.FFFF 0BB 061F38.1.0078 0852AD ----- ------ 00042000 11111111
015C 00000EBCBB7C 00000EB6A7AD 0612D7.1.FFFF 0C4 061F38.1.0079 086007 ----- ------ 00042000 11111111
015D 00000EBCBB7D 00000EB6A7AE 0612D7.1.FFFF 0C5 061F38.1.007A 086D61 ----- ------ 00042000 11111111
015E 00000EBCBB7E 00000EB6A7AF 0612D7.1.FFFF 0C6 061F38.1.007B 087ABB ----- ------ 00042000 11111111
015F 00000EBCBB7F 00000EB6A7B0 0612D7.1.FFFF 0C7 061F38.1.007C 088815 ----- ------ 00042000 11111111
0160 00000EBCBB80 00000EB6A7B1 0612D7.1.FFFF 0C7 061F38.1.007D 08956F ----- ------ 00042000 11111111
0161 00000EBCBB8B 00000EB6A7B2 0612D7.1.FFFF 0D1 061F38.1.007E 08A2C9 ----- ------ 00042000 11111111
0162 00000EBCBB8C 00000EB6A7B3 0612D7.1.FFFF 0D2 061F38.1.007F 08B023 ----- ------ 00042000 11111111
0163 00000EBCBB8D 00000EB6A7B4 0612D7.1.FFFF 0D3 061F38.1.0080 08BD83 ----- ------ 00042000 11111111
0164 00000EBCBB98 00000EB6A7B5 0612D7.1.FFFF 0DD 061F38.1.0081 08CA9D ----- ------ 00042000 11111111
0165 00000EBCBB99 00000EB6A7B6 0612D7.1.FFFF 0DE 061F38.1.0082 08D7F7 ----- ------ 00042000 11111111
0166 00000EBCBB9B 00000EB6A7B7 0612D7.1.FFFF 0DF 061F38.1.0083 08E551 ----- ------ 00042000 11111111
0167 00000EBCBBA6 00000EB6A7B8 0612D7.1.FFFF 0E9 061F38.1.0084 08F2AB ----- ------ 00042000 11111111
0168 00000EBCBBB3 00000EB6A7B9 0612D7.1.FFFF 0F4 061F38.1.0085 090005 ----- ------ 00042000 11111111
0169 00000EBCBBC0 00000EB6A7BA 0612D7.1.FFFF 100 061F38.1.0086 090D5F ----- ------ 00042000 11111111
016A 00000EBCBBC1 00000EB6A7BB 0612D7.1.FFFF 101 061F38.1.0087 091AB9 ----- ------ 00042000 11111111
016B 00000EBCBBC2 00000EB6A7BC 0612D7.1.FFFF 102 061F38.1.0088 092813 ----- ------ 00042000 11111111
016C 00000EBCBBC3 00000EB6A7BD 0612D7.1.FFFF 103 061F38.1.0089 09356D ----- ------ 00042000 11111111
016D 00000EBCBBC6 00000EB6A7BE 0612D8.1.FFFF 124 061F38.1.008A 0942C7 ----- ------ 00042000 11111111
016E 00000EBCBBC7 00000EB6A7BF FFFFFFFF.FF.FFFF 124 061F38.1.008B 094FE1 ----- ------ 00042000 11111111
016F 00000EBCBBD2 00000EB6A7C0 FFFFFFFF.FF.FFFF 12E 061F38.1.008C 095D3B ----- ------ 00042000 11111111
0170 00000EBCBBD3 00000EB6A7C1 FFFFFFFF.FF.FFFF 12F 061F38.1.008D 096A95 ----- ------ 00042000 11111111
0171 00000EBCBBD4 00000EB6A7C2 FFFFFFFF.FF.FFFF 130 061F38.1.008E 0977EF ----- ------ 00042000 11111111
0172 00000EBCBBD5 00000EB6A7C3 FFFFFFFF.FF.FFFF 131 061F38.1.008F 098549 ----- ------ 00042000 11111111
0173 00000EBCBBE0 00000EB6A7C4 FFFFFFFF.FF.FFFF 13A 061F38.1.0090 0992A3 ----- ------ 00042000 11111111
0174 00000EBCBBE1 00000EB6A7C5 FFFFFFFF.FF.FFFF 13B 061F38.1.0091 099FFD ----- ------ 00042000 11111111
0175 00000EBCBBE2 00000EB6A7C6 FFFFFFFF.FF.FFFF 13C 061F38.1.0092 09AD57 ----- ------ 00042000 11111111
0176 00000EBCBBE3 00000EB6A7C7 FFFFFFFF.FF.FFFF 13D 061F38.1.0093 09BAB1 ----- ------ 00042000 11111111
0177 00000EBCBBEF 00000EB6A7C8 FFFFFFFF.FF.FFFF 148 061F38.1.0094 09C80B ----- ------ 00042000 11111111
0178 00000EBCBBF0 00000EB6A7C9 FFFFFFFF.FF.FFFF 149 061F38.1.0095 09D565 ----- ------ 00042000 11111111
0179 00000EBCBBFB 00000EB6A7CA FFFFFFFF.FF.FFFF 152 061F38.1.0096 09E27F ----- ------ 00042000 11111111
017A 00000EBCBBFC 00000EB6A7CB FFFFFFFF.FF.FFFF 153 061F38.1.0097 09EFD9 ----- ------ 00042000 11111111
017B 00000EBCBBFD 00000EB6A7CC FFFFFFFF.FF.FFFF 154 061F38.1.0098 09FD33 ----- ------ 00042000 11111111
017C 00000EBCBC24 00000EB6A7CD FFFFFFFF.FF.FFFF 177 061F38.1.0099 0A0A8D ----- ------ 00042000 11111111
017D 00000EBCBC4A 00000EB6A7CE FFFFFFFF.FF.FFFF 022 061F38.1.009A 0A17E7 ----- ------ 00042000 11111111
017E 00000EBCBC73 00000EB6A7CF FFFFFFFF.FF.FFFF 046 061F38.1.009B 0A2541 ----- ------ 00042000 11111111
017F 00000EBCBC74 00000EB6A7D0 FFFFFFFF.FF.FFFF 047 061F38.1.009C 0A329B ----- ------ 00042000 11111111
0180 00000EBCBC81 00000EB6A7D1 FFFFFFFF.FF.FFFF 053 061F38.1.009D 0A3FF5 ----- ------ 00042000 11111111
0181 00000EBCBC8E 00000EB6A7D2 FFFFFFFF.FF.FFFF 05E 061F38.1.009E 00083F ----- ------ 00042000 11111111
0182 00000EBCBC8F 00000EB6A7D3 FFFFFFFF.FF.FFFF 05F 061F38.1.009F 001599 ----- ------ 00042000 11111111
0183 00000EBCBC9C 00000EB6A7D4 FFFFFFFF.FF.FFFF 06A 061F38.1.00A0 0022F9 ----- ------ 00042000 11111111
0184 00000EBCBC9E 00000EB6A7D5 FFFFFFFF.FF.FFFF 06C 061F38.1.00A1 003013 ----- ------ 00042000 11111111
0185 00000EBCBCAC 00000EB6A7D6 FFFFFFFF.FF.FFFF 079 061F38.1.00A2 003D6D ----- ------ 00042000 11111111
0186 00000EBCBCAD 00000EB6A7D7 FFFFFFFF.FF.FFFF 07A 061F38.1.00A3 004AC7 ----- ------ 00042000 11111111
0187 00000EBCBCAE 00000EB6A7D8 FFFFFFFF.FF.FFFF 07A 061F38.1.00A4 005821 ----- ------ 00042000 11111111
0188 00000EBCBCBB 00000EB6A7D9 FFFFFFFF.FF.FFFF 086 061F38.1.00A5 00657B ----- ------ 00042000 11111111
0189 00000EBCBCBC 00000EB6A7DA FFFFFFFF.FF.FFFF 087 061F38.1.00A6 0072D5 ----- ------ 00042000 11111111
018A 00000EBCBCBD 00000EB6A7DB FFFFFFFF.FF.FFFF 088 061F38.1.00A7 00802F ----- ------ 00042000 11111111
018B 00000EBCBCBE 00000EB6A7DC FFFFFFFF.FF.FFFF 089 061F38.1.00A8 008D89 ----- ------ 00042000 11111111
018C 00000EBCBCCA 00000EB6A7DD FFFFFFFF.FF.FFFF 093 061F38.1.00A9 009AE3 ----- ------ 00042000 11111111
018D 00000EBCBCCB 00000EB6A7DE FFFFFFFF.FF.FFFF 094 061F38.1.00AA 00A83D ----- ------ 00042000 11111111
018E 00000EBCBCCC 00000EB6A7DF FFFFFFFF.FF.FFFF 095 061F38.1.00AB 00B557 ----- ------ 00042000 11111111
018F 00000EBCBCCD 00000EB6A7E0 FFFFFFFF.FF.FFFF 096 061F38.1.00AC 00C2B1 ----- ------ 00042000 11111111
0190 00000EBCBCD7 00000EB6A7E1 FFFFFFFF.FF.FFFF 09F 061F38.1.00AD 00D00B ----- ------ 00042000 11111111
0191 00000EBCBCD8 00000EB6A7E2 FFFFFFFF.FF.FFFF 0A0 061F38.1.00AE 00DD65 ----- ------ 00042000 11111111
0192 00000EBCBCD9 00000EB6A7E3 FFFFFFFF.FF.FFFF 0A0 061F38.1.00AF 00EABF ----- ------ 00042000 11111111
0193 00000EBCBCDA 00000EB6A7E4 FFFFFFFF.FF.FFFF 0A1 061F38.1.00B0 00F819 ----- ------ 00042000 11111111
0194 00000EBCBCE5 00000EB6A7E5 FFFFFFFF.FF.FFFF 0AB 061F38.1.00B1 010573 ----- ------ 00042000 11111111
0195 00000EBCBCE6 00000EB6A7E6 FFFFFFFF.FF.FFFF 0AC 061F38.1.00B2 0112CD ----- ------ 00042000 11111111
0196 00000EBCBCE7 00000EB6A7E7 FFFFFFFF.FF.FFFF 0AD 061F38.1.00B3 012027 ----- ------ 00042000 11111111
0197 00000EBCBE46 00000EB6A7E8 0612D9.1.FFFF 08D 061F38.1.00B4 012D81 ----- ------ 00042000 11111111
0198 00000EBCBE47 00000EB6A7E9 0612D9.1.FFFF 08E 061F38.1.00B5 013ADB ----- ------ 00042000 11111111
0199 00000EBCBE48 00000EB6A7EA 0612D9.1.FFFF 08F 061F38.1.00B6 0147F5 ----- ------ 00042000 11111111
019A 00000EBCBE49 00000EB6A7EB 0612D9.1.FFFF 090 061F38.1.00B7 01554F ----- ------ 00042000 11111111
019B 00000EBCBE4A 00000EB6A7EC 0612D9.1.FFFF 090 061F38.1.00B8 0162A9 ----- ------ 00042000 11111111
019C 00000EBCBE4B 00000EB6A7ED 0612D9.1.FFFF 091 061F38.1.00B9 017003 ----- ------ 00042000 11111111
019D 00000EBCBFC7 00000EB6A7EE 0612DA.1.FFFF 08B 061F38.1.00BA 017D5D ----- ------ 00042000 11111111
019E 00000EBCBFC8 00000EB6A7EF 0612DA.1.FFFF 08C 061F38.1.00BB 018AB7 ----- ------ 00042000 11111111
019F 00000EBCBFD4 00000EB6A7F0 0612DA.1.FFFF 097 061F38.1.00BC 019811 ----- ------ 00042000 11111111
01A0 00000EBCBFD5 00000EB6A7F1 0612DA.1.FFFF 097 061F38.1.00BD 01A56B ----- ------ 00042000 11111111
01A1 00000EBCBFD6 00000EB6A7F2 0612DA.1.FFFF 098 061F38.1.00BE 01B2C5 ----- ------ 00042000 11111111
01A2 00000EBCBFD7 00000EB6A7F3 0612DA.1.FFFF 099 061F38.1.00BF 01C01F ----- ------ 00042000 11111111
01A3 00000EBCBFD8 00000EB6A7F4 0612DA.1.FFFF 09A 061F38.1.00C0 01CD7F ----- ------ 00042000 11111111
01A4 00000EBCBFE2 00000EB6A7F5 0612DA.1.FFFF 0A3 061F38.1.00C1 01DA99 ----- ------ 00042000 11111111
01A5 00000EBCBFE3 00000EB6A7F6 0612DA.1.FFFF 0A4 061F38.1.00C2 01E7F3 ----- ------ 00042000 11111111
01A6 00000EBCBFE4 00000EB6A7F7 0612DA.1.FFFF 0A5 061F38.1.00C3 01F54D ----- ------ 00042000 11111111
01A7 00000EBCBFE5 00000EB6A7F8 0612DA.1.FFFF 0A6 061F38.1.00C4 0202A7 ----- ------ 00042000 11111111
01A8 00000EBCBFE6 00000EB6A7F9 0612DA.1.FFFF 0A6 061F39.1.0000 02E52F ----- ------ 00000122 00000000
01A9 00000EBCBFEF 00000EB6A7FA 0612DA.1.FFFF 0AE 061F39.1.0001 02F249 ----- ------ 00042000 11111111
01AA 00000EBCBFF0 00000EB6A7FB 0612DA.1.FFFF 0AF 061F39.1.0002 02FFA3 ----- ------ 00042000 11111111
01AB 00000EBCBFF1 00000EB6A7FC 0612DA.1.FFFF 0B0 061F39.1.0003 030CFD ----- ------ 00042000 11111111
01AC 00000EBCBFF2 00000EB6A7FD 0612DA.1.FFFF 0B1 061F39.1.0004 031A57 ----- ------ 00042000 11111111
01AD 00000EBCBFF3 00000EB6A7FE 0612DA.1.FFFF 0B2 061F39.1.0005 0327B1 ----- ------ 00042000 11111111
01AE 00000EBCBFFD 00000EB6A7FF 0612DA.1.FFFF 0BB 061F39.1.0006 03350B ----- ------ 00042000 11111111
01AF 00000EBCBFFE 00000EB6A800 0612DA.1.FFFF 0BC 061F39.1.0007 034265 ----- ------ 00042000 11111111
01B0 00000EBCBFFF 00000EB6A801 0612DA.1.FFFF 0BD 061F39.1.0008 034FBF ----- ------ 00042000 11111111
01B1 00000EBCC000 00000EB6A802 0612DA.1.FFFF 0BD 061F39.1.0009 035D19 ----- ------ 00042000 11111111
01B2 00000EBCC001 00000EB6A803 0612DA.1.FFFF 0BE 061F39.1.000A 036A73 ----- ------ 00042000 11111111
01B3 00000EBCC00B 00000EB6A804 0612DA.1.FFFF 0C7 061F39.1.000B 03778D ----- ------ 00042000 11111111
01B4 00000EBCC00C 00000EB6A805 0612DA.1.FFFF 0C8 061F39.1.000C 0384E7 ----- ------ 00042000 11111111
01B5 00000EBCC00D 00000EB6A806 0612DA.1.FFFF 0C9 061F39.1.000D 039241 ----- ------ 00042000 11111111
01B6 00000EBCC00E 00000EB6A807 0612DA.1.FFFF 0CA 061F39.1.000E 039F9B ----- ------ 00042000 11111111
01B7 00000EBCC019 00000EB6A808 0612DA.1.FFFF 0D4 061F39.1.000F 03ACF5 ----- ------ 00042000 11111111
01B8 00000EBCC01A 00000EB6A809 0612DA.1.FFFF 0D4 061F39.1.0010 03BA4F ----- ------ 00042000 11111111
01B9 00000EBCC01B 00000EB6A80A 0612DA.1.FFFF 0D5 061F39.1.0011 03C7A9 ----- ------ 00042000 11111111
01BA 00000EBCC01C 00000EB6A80B 0612DA.1.FFFF 0D6 061F39.1.0012 03D503 ----- ------ 00042000 11111111
01BB 00000EBCC026 00000EB6A80C 0612DA.1.FFFF 0DF 061F39.1.0013 03E25D ----- ------ 00042000 11111111
01BC 00000EBCC027 00000EB6A80D 0612DA.1.FFFF 0E0 061F39.1.0014 03EFB7 ----- ------ 00042000 11111111
01BD 00000EBCC028 00000EB6A80E 0612DA.1.FFFF 0E1 061F39.1.0015 03FD11 ----- ------ 00042000 11111111
01BE 00000EBCC029 00000EB6A80F 0612DA.1.FFFF 0E2 061F39.1.0016 040A2B ----- ------ 00042000 11111111
01BF 00000EBCC033 00000EB6A810 0612DA.1.FFFF 0EB 061F39.1.0017 041785 ----- ------ 00042000 11111111
01C0 00000EBCC034 00000EB6A811 0612DA.1.FFFF 0EB 061F39.1.0018 0424DF ----- ------ 00042000 11111111
01C1 00000EBCC035 00000EB6A812 0612DA.1.FFFF 0EC 061F39.1.0019 043239 ----- ------ 00042000 11111111
01C2 00000EBCC036 00000EB6A813 0612DA.1.FFFF 0ED 061F39.1.001A 043F93 ----- ------ 00042000 11111111
01C3 00000EBCC041 00000EB6A814 0612DA.1.FFFF 0F7 061F39.1.001B 044CED ----- ------ 00042000 11111111
01C4 00000EBCC042 00000EB6A815 0612DA.1.FFFF 0F8 061F39.1.001C 045A47 ----- ------ 00042000 11111111
01C5 00000EBCC043 00000EB6A816 0612DA.1.FFFF 0F9 061F39.1.001D 0467A1 ----- ------ 00042000 11111111
01C6 00000EBCC04E 00000EB6A817 0612DA.1.FFFF 102 061F39.1.001E 0474FB ----- ------ 00042000 11111111
01C7 00000EBCC04F 00000EB6A818 0612DA.1.FFFF 103 061F39.1.001F 048255 ----- ------ 00042000 11111111
01C8 00000EBCC050 00000EB6A819 0612DA.1.FFFF 104 061F39.1.0020 048FB5 ----- ------ 00042000 11111111
01C9 00000EBCC051 00000EB6A81A 0612DA.1.FFFF 105 061F39.1.0021 049CCF ----- ------ 00042000 11111111
01CA 00000EBCC05B 00000EB6A81B 0612DA.1.FFFF 110 061F39.1.0022 04AA29 ----- ------ 00042000 11111111
01CB 00000EBCC05C 00000EB6A81C 0612DA.1.FFFF 111 061F39.1.0023 04B783 ----- ------ 00042000 11111111
01CC 00000EBCC067 00000EB6A81D 0612DA.1.FFFF 11A 061F39.1.0024 04C4DD ----- ------ 00042000 11111111
01CD 00000EBCC068 00000EB6A81E 0612DA.1.FFFF 11B 061F39.1.0025 04D237 ----- ------ 00042000 11111111
01CE 00000EBCC069 00000EB6A81F 0612DA.1.FFFF 11C 061F39.1.0026 04DF91 ----- ------ 00042000 11111111
01CF 00000EBCC076 00000EB6A820 0612DA.1.FFFF 128 061F39.1.0027 04ECEB ----- ------ 00042000 11111111
01D0 00000EBCC077 00000EB6A821 0612DA.1.FFFF 128 061F39.1.0028 04FA45 ----- ------ 00042000 11111111
01D1 00000EBCC084 00000EB6A822 0612DA.1.FFFF 134 061F39.1.0029 05079F ----- ------ 00042000 11111111
01D2 00000EBCC091 00000EB6A823 0612DA.1.FFFF 13F 061F39.1.002A 0514F9 ----- ------ 00042000 11111111
01D3 00000EBCC11E 00000EB6A824 0612DB.1.FFFF 062 061F39.1.002B 052213 ----- ------ 00042000 11111111
01D4 00000EBCC11F 00000EB6A825 0612DB.1.FFFF 063 061F39.1.002C 052F6D ----- ------ 00042000 11111111
01D5 00000EBCC120 00000EB6A826 0612DB.1.FFFF 064 061F39.1.002D 053CC7 ----- ------ 00042000 11111111
01D6 00000EBCC121 00000EB6A827 0612DB.1.FFFF 065 061F39.1.002E 054A21 ----- ------ 00042000 11111111
01D7 00000EBCC138 00000EB6A828 0612DB.1.FFFF 07B 061F39.1.002F 05577B ----- ------ 00042000 11111111
01D8 00000EBCC139 00000EB6A829 0612DB.1.FFFF 07C 061F39.1.0030 0564D5 ----- ------ 00042000 11111111
01D9 00000EBCC13A 00000EB6A82A 0612DB.1.FFFF 07D 061F39.1.0031 05722F ----- ------ 00042000 11111111
01DA 00000EBCC13B 00000EB6A82B 0612DB.1.FFFF 07E 061F39.1.0032 057F89 ----- ------ 00042000 11111111
01DB 00000EBCC13C 00000EB6A82C 0612DB.1.FFFF 07F 061F39.1.0033 058CE3 ----- ------ 00042000 11111111
01DC 00000EBCC149 00000EB6A82D 0612DB.1.FFFF 08A 061F39.1.0034 059A3D ----- ------ 00042000 11111111
01DD 00000EBCC2E1 00000EB6A82E 0612DC.1.FFFF 09D 061F39.1.0035 05A797 ----- ------ 00042000 11111111
01DE 00000EBCD6D3 00000EB6A83A 0612E8.1.FFFF 0BC 061F39.1.0041 064755 ----- ------ 00002600 11111111
01DF 00000EBCD6D4 00000EB6A83B 0612E8.1.FFFF 0BD 061F39.1.0042 0654AF ----- ------ 00002610 11111111
F3 T>V40
HighPowerMode
XI2
TCC:0025:003CStatus 0001 Req 0002Nonresident GList 12 entries returned
Total entries available: 12
0 46BCC 40 0 0 0 3
1A1FE4 410FA 40 0 1 0 8DAB3
5A013A5 172 0 1F01D 1 0 4D7C3
60265B0 162 0 210FB 1 0 78CF3
8132F19 151 0 2DBA9 1 0 E5E34
8B44014 148 0 317D8 1 0 E577
94EC6CA 13E 0 3558B 1 0 CDF53
955F53A 13E 0 35B53 1 0 E4393
9F8C920 132 0 3A3F2 1 0 788AF
A20BCEC 122 0 3B31E 1 0 C2E95
A21AD14 122 0 3B3F2 1 0 AE875
AA8B30C 124 0 3EC7C 1 0 17096
AAD791E 122 0 3F0AF 1 0 CF697
AE0599F 11F 0 4084B 1 0 2FD10
AE59554 11F 0 40CF6 1 0 819B2
BA1F687 10F 0 46C92 1 0 C9593
DE9C738 D9 0 5977B 1 0 1BCFB
E35DE3B CF 0 5C614 1 0 42064
F3 T>
PrgF
Don't know how to safetly proceed to read customer user datas.
Can someone help me?
Best regards
Boot 0x80M
Reply:
QB
Rst 0x80M
(P) SATA Reset
RAW OFF
PASS
MSP213
Intel 6G->3G
CSpd= 3Gbps
DSC
PowerState = IDLE1
VC0
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
PowerState =
HighPowerMode
VC1
VC2Up:
PowerState = IDLE1
VC0
HighPowerMode
XI2
VC1
PowerState = IDLE2
VC0
HighPowerMode
VC1
VC2Up:
PrgF
F3 T>V4
F3 T>V40
HighPowerMode
XI2
0 46BCC 40 0 0 0 3
F3 T>
PrgF
Best regards
