No HOST FIS-ReadyStatusFlags 0002A185
Posted: 06.04.20, 13:17
hello all ,
Pls help me as i have drive seagate 500gb MOdel:st3500DM002 FW : KC44 ITS DETAIL IS AS GIVEN BELOW.
TERMINAL:
Boot 0x10M
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
MCMainPOR: EXCEPTION: SIM aborted prior to MCMT read
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled... PASS
BY PRESSING CTRL+L
F3 T>
PH0G + 4K + MC + TWM,RAP16,Common Code 4, QNC
Product FamilyId: 3F, MemberId: 05
HDA SN: Z2AD6RQX, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 0000075D672F, PreampType: 73 23
PCBA SN: 0000C209CGXR, Controller: YETIST_3_*/4_0(64A1)(3-12-4-1), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000
Package Version: PH0X2D.CCD4.AABZ00., Package P/N: 100684526, Package Global ID: 00410638,
Package Build Date: 07/28/2011, Package Build Time: 10:29:33, Package CFW Version: PH0X.CCD4.00376961.00410638,
Package SFW1 Version: D28A, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 07281029, CustomerRel: KC44, Changelist: 00376961, ProdType: PH0X.CCD4, Date: 07/28/2011, Time: 102933, UserId: 00410638
Servo FW Rev: D28A
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 0A 1B 03
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC disabled
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
EFFORTS WHICH I HAVE MADE :
Backup neccesary sys files.Than
F3T>Z
F3T>U
F3T>V4
F#T>V1
F3t>V40 no defects
than m0,2,2,,,,,22
POwer off and on and result is same.
so i tried no host fis patch but it says "CFW code segment is not found.this patch work on st3500418as and st3500413as .but not on this.
Pls help me how to patch no hostfis-readystatusflags 0002A185
.I have also tried for pin shorting but at the end results are same.here i attached terminal.
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
(DOS) Requesting File Save
Starting LBA of RW Request=00131F40 Length=00000128
ProcessRWError -Read- at LBA 00131F40 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F44 Length=00000124
ProcessRWError -Read- at LBA 00131F44 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F48 Length=00000120
ProcessRWError -Read- at LBA 00131F48 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F4C Length=0000011C
ProcessRWError -Read- at LBA 00131F4C Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F50 Length=00000118
ProcessRWError -Read- at LBA 00131F50 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F54 Length=00000114
ProcessRWError -Read- at LBA 00131F54 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F58 Length=00000110
ProcessRWError -Read- at LBA 00131F58 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F5C Length=0000010C
ProcessRWError -Read- at LBA 00131F5C Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F60 Length=00000108
ProcessRWError -Read- at LBA 00131F60 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F64 Length=00000104
ProcessRWError -Read- at LBA 00131F64 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F68 Length=00000100
ProcessRWError -Read- at LBA 00131F68 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F6C Length=000000FC
ProcessRWError -Read- at LBA 00131F6C Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F70 Length=000000F8
ProcessRWError -Read- at LBA 00131F70 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F74 Length=000000F4
ProcessRWError -Read- at LBA 00131F74 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F78 Length=000000F0
ProcessRWError -Read- at LBA 00131F78 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F7C Length=000000EC
ProcessRWError -Read- at LBA 00131F7C Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F80 Length=000000E8
ProcessRWError -Read- at LBA 00131F80 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F84 Length=000000E4
ProcessRWError -Read- at LBA 00131F84 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F88 Length=000000E0
ProcessRWError -Read- at LBA 00131F88 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F8C Length=000000DC
ProcessRWError -Read- at LBA 00131F8C Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F90 Length=000000D8
ProcessRWError -Read- at LBA 00131F90 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F94 Length=000000D4
ProcessRWError -Read- at LBA 00131F94 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F98 Length=000000D0
ProcessRWError -Read- at LBA 00131F98 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131F9C Length=000000CC
ProcessRWError -Read- at LBA 00131F9C Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FA0 Length=000000C8
ProcessRWError -Read- at LBA 00131FA0 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FA4 Length=000000C4
ProcessRWError -Read- at LBA 00131FA4 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FA8 Length=000000C0
ProcessRWError -Read- at LBA 00131FA8 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FAC Length=000000BC
ProcessRWError -Read- at LBA 00131FAC Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FB0 Length=000000B8
ProcessRWError -Read- at LBA 00131FB0 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FB4 Length=000000B4
ProcessRWError -Read- at LBA 00131FB4 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FB8 Length=000000B0
ProcessRWError -Read- at LBA 00131FB8 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FBC Length=000000AC
ProcessRWError -Read- at LBA 00131FBC Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FC0 Length=000000A8
ProcessRWError -Read- at LBA 00131FC0 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FC4 Length=000000A4
ProcessRWError -Read- at LBA 00131FC4 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FC8 Length=000000A0
ProcessRWError -Read- at LBA 00131FC8 Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FCC Length=0000009C
ProcessRWError -Read- at LBA 00131FCC Sense Code=43110081
RTL exceeded
Starting LBA of RW Request=00131FD0 Length=00000098
ProcessRWError -Read- at LBA 00131FD0 Sense Code=43110081
ProcessRWError -Read- at LBA 00131FD1 Sense Code=43110081
RTL exceeded
I have tried with pcb swap with native rom too.
thanks in advance pls help.
TERMINAL:
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
BY PRESSING CTRL+L
F3 T>
Servo FW Rev: D28A
Features:
- IOEDC enabled
- IOECC disabled
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
F3T>Z
F3T>U
F3T>V4
F#T>V1
F3t>V40 no defects
than m0,2,2,,,,,22
Boot 0x10M
Trans.
Rst 0x10M
Spin Up
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
RTL exceeded
