Strange preamp problem
Posted: 12.02.20, 01:46
by Mekanik
I have meet a strange situation on reading a preamp value.
If i read preamp value from terminal (CTRL+L) I have a result like: 73 03
Instead If read rom via bootloader (or same using external reader) result is 03 73
Something wrong? :shockable:
In attach 2 log of same disk ST500DM002-1BD142
from_ROM.txt
(9.18 KiB) Downloaded 334 times
from_terminal.txt
(1.1 KiB) Downloaded 368 times
Re: Strange preamp problem
Posted: 12.02.20, 08:09
by k4z1
In ROM the data is stored in little-endian format.
So swap the bytes and you will have the same type, as from terminal.
Posted: 14.02.20, 10:48
by Mekanik
Thanks for useful info but.............
Other disk: ST9500325AS
Preamp by CTRL+L -------> 5A 15
Preamp by BootCode -----> 00 54 :shockable: !!!!!
By_terminal.txt
(1.1 KiB) Downloaded 314 times
By_rom_bootcode.txt
(8.44 KiB) Downloaded 323 times
Posted: 17.02.20, 08:14
by northwind
Mekanik wrote:Source of the post
Based on your Bootcode:
Flags.................... : 009A
Preamp type.............. : 005A
Phys head maps........... : 00 01 02 03
: 00 01 02 03
