Editing head map on ST31000528AS
Posted: 11.01.20, 22:02
by Freakazoid
Is it not possible to edit the head map on this ST31000528AS drive? if I set ROM physical head maps from 00 01 02 03 to 00 00 00 00
and same on ROM logical head map and edit SAP control flags max head to 0, then the hard drive will not start spinning (it behaves as if the circuit board is shorted but at the same time it gives the error message in terminal: Bad CRC Seg: 0x05
Bad CRC Seg: 0x24Bogus ISR
CPSR = 0x200000D2
R14 = 0x00001CFC
Im using Pc3000
(at least one of the heads is defective. what I'm trying to figure out is if head 0 still works
(this is my own hard drive for exploration only))
( I was able to do it on another ST31000528AS why is it posibal only on some and not all of them)
Re: Editing head map on ST31000528AS
Posted: 12.01.20, 15:09
Boss ,
If you have access to logical head map i rom just set those and experiement ,Do not bother about anything else ,The SAP is Used When You Want To Fool The Drive Only 2 Primary heads Are Present in the drive
Posted: 12.01.20, 17:05
by Freakazoid
Amarbir[CDR-Labs] wrote:Source of the post Boss ,
I'm still pretty new in this business .. I'm not sure how to edit the head i rom . I just know that if I edit head in ROM physical headers and head 00 is functional, it gives an opportunity to disable the bad head then you can copy the good heads before switching
Posted: 12.01.20, 19:27
by Freakazoid
Solved =) I figured it out =)
Posted: 14.01.20, 10:20
by computershopee
How you solved it..
In our forum you have to share your experience.
then it will help others..
Happy Day
:thumbup:
Posted: 16.01.20, 09:25
by Maxim_TS
I suppose the issue was in some head really, but it's also necessary to make changes in ROM under not F3 Arch (Common), but the appropriate family: Pharaoh in this case.
Posted: 16.01.20, 15:04
by Freakazoid
computershopee wrote:Source of the post How you solved it..
Happy Day
:thumbup:
You need to edit head map in all rom. not only the first.
Posted: 22.12.20, 05:05
by elbote83
can you be more specific with the solution??
Posted: 08.01.21, 17:40
elbote83 wrote:Source of the post can you be more specific with the solution??
The answer was specific - he modified the map of active heads in the ROM and write back to drive - this makes drive start with alternate map of heads and damaged head removed. For example, if HDD has 2 heads and H1 is bad, ideally we change max head count to '0' that makes new map show as '0' only - thus removing H1 and HDD does not look for it so gives no errors as H0 is working.
As this HDD has multiple heads the failed head should be identified and removed from the map, either by modifying max head count then adjusting map accordingly to remove bad head, or 'pairing' bad head by replacing it with some known good head in ROM map.
