ST1000LX015 No moment (Not Spining)
bikram
Postby bikram » 26.12.19, 04:04
I have ST1000LX15 (Mobile HDD) Hard Disk not spinning. may be corruption in Rom Any one have any Solution Please help ....
Thanks & Regard
Bikram Singh
Re: ST1000LX015 No moment (Not Spining)
Postby digitalsupport » 27.12.19, 12:08
Status register and terminal output will most likely give you a hint
Postby Amarbir[CDR-Labs] » 29.12.19, 12:34
bikram wrote:Source of the post Hi,
This is a SSHD ,Check Terminal And Post Result Also Status Registers
bikram
Postby bikram » 02.01.20, 06:14
Boot 0x80M DensityList:0x0000
PrgF
LED:0x000000BD FAddr:0x000059D8
Thanks & Regard
Bikram Singh
computershopee
Postby computershopee » 10.01.20, 13:09
Try to shorting the pcb by instructing by manual...
i success & got the data 1000 GB..
once you go with solution for unlolck 00000CD process
First we have to get >T
when you got you will success.. i tried for 3 days to get >T & finally got it. :wave:
https://forum.acelab.eu.com/viewtop ... 4&p=37327#
Good Luck
Srinivas
Computer shopee Data Recovery
Postby Amarbir[CDR-Labs] » 12.01.20, 15:07
bikram wrote:Source of the post Boot 0x80M DensityList:0x0000
PrgF
Hello ,
Bad Media Cache According To My Experience
k4z1
Postby k4z1 » 13.01.20, 14:08
It´s not media cache issue.
It´s NAND issue. Ace doesn´t have a solution yet.
datasalvage
Postby datasalvage » 14.02.24, 05:17
computershopee wrote:Source of the post Try to shorting the pcb by instructing by manual...
hello Sir does this solution work for ST2000LX001 too? i tried the official guide here https://blog.acelab.eu.com/how-to-fix-a ... -chip.html
with donor after Repeat the unlocking steps (1-6) i cannot enter the command OI1 ..... i will get LED:0x000000BD FAddr:0x000059D8 !again
and if i skip this command and Repeat the unlocking steps (7-9). i get Waiting drive spin up !
with original PCB the drive spins if i change to 82 34 56 78 but i cant enter the command OI1
ps can ou share the solution for unlolck 00000CD process ?
datasalvage
Postby datasalvage » 20.02.24, 06:33
can somebody tell me which is the correct position for the read channell? i tried many times but is still get the error LED:0x000000BD FAddr:0x00008004
should i short before or after the tech Unlock Handshake"?
should i keep the position untill the drive get ready ? if the position is correct will the drive keep spinning or will stop spins?
