Rosewood , FW: SDM 2 . no ID and Capacity.
Posted: 11.08.19, 14:21
by betty
hello to all,
I hv one 1tb Seag Mobile hdd family :Rosewood , FW: SDM 2 .
Smooth spinning, module can access... But no ID and Capacity....i tried to remove the background process from 93h... no luck... showing error in terminal
" Unsupported FW"
I tried translator regen ,after taking and imp system files... its completed successfully , but no luck no ID& Capacity .
I marked one thing, when ever its giving error ,the status register blinks with DSC DWG DRD also AMN & ERR
Any one have the same experience, please share any solution
Re: Rosewood , FW: SDM 2 . no ID and Capacity.
Posted: 11.08.19, 15:04
by SGdata
Did you write 93 via terminal or indirect?
Posted: 11.08.19, 18:51
by digitalsupport
Try to disable idle activity via terminal
Posted: 12.08.19, 05:13
by hdd00
Most likely the drive have corrupted/unreadable MC table module......Try to correct that.
Posted: 13.08.19, 07:13
by betty
SGdata wrote:Did you write 93 via terminal or indirect?
Can you provide terminal command for modification of 93
thanks
Posted: 13.08.19, 07:49
by SGdata
Posted: 13.08.19, 12:05
by lka124
betty wrote:Source of the post I tried translator regen ,after taking and imp system files... its completed successfully , but no luck no ID& Capacity .
from Blog about that: DO NOT regenerate the translator on Rosewood family.
Posted: 13.08.19, 15:26
by Paradog84
Backup important files via terminal (93, 1B, 28, 346 & 348)
Then flush MC from /C level in terminal using command "U10"
Posted: 14.08.19, 16:28
by betty
Paradog84 wrote:Backup important files via terminal (93, 1B, 28, 346 & 348)
thanks to all
Posted: 16.10.19, 20:23
by AYNIADAM
I get the same error rosewood. Abr problem. terminal connected. translator backup. Is there a solution to this error?
Posted: 26.10.19, 19:44
by AYNIADAM
I still haven't found a solution. please help me.
