ST2000DM006
avalanche
ST2000DM006
Postby avalanche » 10.02.19, 11:09
Hello All,
I've just seen in my first ST2000DM006 series HDD with a head failure. I wondered if anyone had any experience on donor part compatibility with these? Inside the failed HDD it uses two platters, using 0,1,2,3. Has anyone seen there much variation in the head-map? Out of interest, how much higher is the areal density in the DM006 vs the DM001?
At this stage I can find some reasonable match donor HDDs at decent prices so will order some in this week.
Regards,
John
avalanche
Re: ST2000DM006
Postby avalanche » 10.02.19, 17:30
I've had some time this afternoon to do some testing with some old HDDs and the new ST2000DM006. ST2000DM006 and recent revisions of ST2000DM001 are rather similar, to say the least.
Areal density is the same, or at least close enough. Pre-amp revisions look the same, with donor head compatibility possible - just got the DM006 imaging now :) The ST2000DM006 patient was manufactured February 2017. The donor used was from a ST2000DM001, manufactured in September 2014. Clearly, Seagate are not changing a great deal!
Regards,
John
Blizzard
Re: ST2000DM006
Postby Blizzard » 10.02.19, 19:42
Thanks for the update. Out of curiosity, were the preamp codes B3- or CB-?
avalanche
Re: ST2000DM006
Postby avalanche » 10.03.19, 19:30
Sorry for the delay. Full details for each HDD listed below. Good compatibility.
Patient: ST2000DM006 / Z4Z7K1NR / 2DM164-302 / CC26 / 100762568 REV A / 03FEB2017 / TK
Donor heads from: ST2000DM001 / Z4Z156LB / 1ER164-570 / CC45 / 100724095 REV A / 09/2014 / TK
The disk imaged very well. It was not necessary to import the head-adaptives.
Regards,
John
FLASH ROM Info
Image size............... : 1048576
QNR Revisions:
Flash ROM image.......... : 1
GLOB_FLASH_DIR........... : 1
BOOTFW_CONT_0............ : 0
GLOB_FLASH_DIR........... : 0
BOOTFW_CONT_1............ : 0
CAP
Validation Key........... : 0x00000020
Fam ID................... : 0x58 (Grenada)
Fam Member............... : 0x4
Head count............... : 4
Date..................... : 03 Feb 2017
SN....................... : Z4Z7K1NR
PCB SN................... : 0000W730ZYX8
PCB PN................... : ÿÿÿÿÿÿÿÿÿÿ
WWN...................... : 5000C500A24B291F
MDL1..................... : ST2000DM006-2DM164
MDL2..................... : ST2000DM006
Capacity................. : 3907029168
RAP
Format revision.......... : 0x0005
Contents revision........ : 0x06030200
Number Sys Zones......... : 1
Number User Zones........ : 60
Heads count.............. : 4
FW Implementation Key.... : 0x16
SAP
Fam ID................... : 0x58, (Grenada)
Servo FW rev code........ : 0xCB5C
Max head................. : 3
Seek mode................ : 2020
Flags.................... : 1A09
RRO mode................. : 0005
Preamp type.............. : 07D1
Heads polarity........... : 00 00 00 00 00 00 00 00 00 00
Logical head map......... : 00 01 02 03 04 05 06 07 08 09
Phys head maps........... : 00 01 02 03 04 05 06 07 08 09
CODE info
Bank 0
ProdType................. : G2AED30.CCD2
Controller FW Rev........ : 09141130
Customer Release......... : CC26
Changelist............... : 01094228
Build date / time........ : 14/09/2016 11:30:48
Package Global ID........ : 00503913
Package Builder ID....... :
Build Rev................ :
Package Rev.............. : HS20DY
Pkg P/N.................. : 100809195
Servo FW................. : C35F / B35F / D35F / ----
Package Version.......... : G2AED30.CCD2.HS20DY.CC26
Pkg CFW Ver.............. : G2AED30.CCD2.01094228.00503913
Bank 1
FLASH ROM Info
QNR Revisions:
CAP
Date (ERROR!)............ : 39 - 14 -
SN....................... : Z4Z156LB
PCB SN................... : 0000R511FGH7
WWN...................... : 5000C500798FAB88
MDL1..................... : ST2000DM001-1ER164
MDL2..................... : ST2000DM001
RAP
SAP
Servo FW rev code........ : 0xCD56
Preamp type.............. : 04B6
CODE info
Bank 0
ProdType................. : G2AED30.CCD4
Controller FW Rev........ : 06231606
Customer Release......... : CC45
Changelist............... : 00722275
Build date / time........ : 23/06/2014 16:06:16
Package Global ID........ : 00210313
Package Rev.............. : GG23DY
Pkg P/N.................. : 100757705
Servo FW................. : C554 / B554 / D554 / ----
Package Version.......... : G2AED30.CCD4.GG23DY.CC45
Pkg CFW Ver.............. : G2AED30.CCD4.00722275.00210313
Bank 1
Blizzard
Re: ST2000DM006
Postby Blizzard » 11.03.19, 15:04
Thanks for the feedback, and boy was my guess wrong :)
D1 and B6. I don't seem to recall seeing a B6 for a 2TB DM before. Most I see are CB and then B3, D1, and A8.
Re: ST2000DM006
Postby Amarbir[CDR-Labs] » 29.07.20, 14:58
Update Boys ,
Today i see a Busy ST2000DM001 With following Details
Preamp type.............. : 06CC
Users browsing this forum: gautam.dotcom and 12 guests
