ST1000lm035-long message in terminal
Posted: 29.01.19, 10:56
by jojo2012
Hi guys,
I'm handling this Rosewood and after power up it calibrates fine, no mechanical noise, get RDY DSC in status register.
In terminal I get the long message in attached. So far I had not seen a similar message.
Do you have any idea what it could be?
Thanks so much
Jojo
Terminal.txt
(16.03 KiB) Downloaded 542 times
Re: ST1000lm035-long message in terminal
Posted: 29.01.19, 11:02
by pclab
Can you read modules and Sys files?
Posted: 30.01.19, 16:55
by jojo2012
No I have not yet started to read the modules and Sys files.
I wanted to send a preliminary quotation based on the output of the terminal. Tomorrow I will start testing.
Thanks for the reply Pclab...I'll let you know.
Jojo
Posted: 31.01.19, 13:58
by pclab
Maybe It's something I do wrong, but I usually "almost" or even repair the drive before making a quote (or if it's something a little harder to do, like a headswap).
Only then I know what's wrong and give the proper quote.
Like this I know the problem is solvable and if it will take 1 day or 2 days or 2 weeks.
Posted: 07.02.19, 14:10
by Maxim_TS
Are 348 and 28 system files readable using COM-port?
Posted: 20.02.19, 10:50
by jojo2012
Sorry Guys for the delay of the reply but I wanted to do some tests and I got 99.20% of the data.
Yes I was able to read the most important Sys files and modules. Then after translator regeneration and edit 93 Sys file I managed to get the complete ID.
Only I did not have full access to the sectors.
So I loaded the Sys file 35 (previously saved) written to the drive and run translator regeneration. I managed to read 1856515558 sectors.
Unfortunately, the drive had reading problems, by an amazing coincidence on the MFT.
But I think the structure of the main folders managed to get it, together with “Lost & Found”.
Unfortunately I tried the various methods of restoring the translator but without success.
In attached the log and terminal.
Anyway thanks for the reply.
Jojo
Terminal-Translator-Recovery.log
(32.05 KiB) Downloaded 487 times
Log-Translator-Recovery.log
(26.68 KiB) Downloaded 442 times
Posted: 20.02.19, 10:55
by jojo2012
pclab wrote:Source of the post Maybe It's something I do wrong, but I usually "almost" or even repair the drive before making a quote (or if it's something a little harder to do, like a headswap).
PcLab I know that doing most of the work you can be more precise about the quotation, but I do not really like repairing the drive and doing most of job, and then maybe, get a refusal of the estimate.
