ace please explain rom adaptives - many unanswered questions
Re: ace please explain rom adaptives - many unanswered questions
Postby DataMedics » 29.12.15, 17:09
What were the original symptoms? Was the drive clicking and spinning down, or did it sound fairly normal on startup?
cuumaytinh
Postby cuumaytinh » 13.01.16, 09:23
DataMedics wrote:Source of the post What were the original symptoms? Was the drive clicking and spinning down, or did it sound fairly normal on startup?
some time it clicking and down. some time ít sound hear as normal but with noise sound.
I do not have solutions for the correct handling of this case . I just can say to clients that disk face scratched.
I has tried on two hard drives good and duplicity from each other and it runs very well .
Postby DataMedics » 13.01.16, 18:35
Have you tried ldr and dir upload to see if you can read the SA tracks from either head or even trough composite reading? Possibly it's just SA damage and you could recover by setting up a smart hot start drive.
cuumaytinh
Postby cuumaytinh » 14.01.16, 07:28
DataMedics wrote:Have you tried ldr and dir upload to see if you can read the SA tracks from either head or even trough composite reading? Possibly it's just SA damage and you could recover by setting up a smart hot start drive.
you can teach more about this? I really thank you for your reply.
cuumaytinh
Postby cuumaytinh » 18.01.16, 05:52
Rst 0x10M
MC Internal LPC Process
Spin Up
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
this log after change head. . has inporting adative head from rom donor hdd
Nick_TS
Postby Nick_TS » 18.01.16, 18:25
cuumaytinh wrote:Source of the post smart hot start drive.
There is no hot-swap on Seagate F3 drives.
day1data
Postby day1data » 19.01.16, 09:49
cuumaytinh wrote:it really is not clear. Sometimes I was change head from including model. P/N. First 3 numbers of S/N and producing contry. but failed
Its common that these drives suffer a head crash on one of the bottom platters out of sight. Check the heads under a microscope to see if they are dirty before trying the head swap.
If you put the patient heads back into the donor and the heads no longer work then you know that scratches killed the donor heads.
Postby DataMedics » 19.01.16, 22:42
Dmitriy_TS wrote:Source of the post
You're right, my mistake. I must have been going back and forth between a few threads and got confused which drive we were talking about.
