Seagate 2 Tb Rosewood_A5 ST2000LM007 busy
dan.florian.mihai
Postby dan.florian.mihai » 11.03.26, 14:00
I have a Seagate 2 Tb Rosewood_A5 ST2000LM007 busy
I have donwloaded ROM with bootcode and it says WARNING! Segment header check sum is invalid!
I believe I need to reflash the ROM using a donor. Any ideas how to get around this? I am stuck
Thank you,
Dan
CAP
Fam ID................... : 0xA5 (Rosewood_A5)
Head count............... : 4
Date..................... : 26 Oct 2016
SN....................... : WDZ12L3B
PCB SN................... : 0000K7170BF2
PCB PN................... :
WWN...................... : 5000C5009DE5F502
This is the terminal
Boot 0x80M
FAIL Servo Op=0100 Resp=0003
0100 0001 4004 551E 4068 8208 5DFD 5176 767D F8FE 0839 9B6C 4422 489B FEB6 D71F 87FC FFFC 49A1 930D 0E38 4125 CFF5 7A7B FCBC 4FDD 1C00 3640 1276 D4C5 DEAD 7EDE
ResponseFrame 0018 1809 0021 0006 0A65 0003 0000 0000 0000 8AF2 2544 1252 ECB7 6B6D E2F9 A67A 6E25 602F E506 20A1 4CD5 DEFB 3EAF BACC 8213 B4C0 E58A 0244 7FBB FB8B AFEF BDF8 0007
ROM bootcode..txt
(5.91 KiB) Downloaded 128 times
SGdata
Re: Seagate 2 Tb Rosewood_A5 ST2000LM007 busy
Postby SGdata » 13.03.26, 07:24
Reflash using a donor? NO! You need original ROM.
dan.florian.mihai
Postby dan.florian.mihai » 14.03.26, 18:50
My apologies for not giving details
The original ROM has a container error, and can't acces the terminal it gives a fail servo error
The ROM is integrated in the controller
I was wondering if I can use a donor rom and copy into it the originalROM adaptives in hex editor? Is there anything else I can do?.
Thank you for your help.
SGdata
Postby SGdata » 17.03.26, 08:09
Check the original ROM. Container error message does not mean that the ROM is damaged. fail servo means that heads cannot read SA.
You can upload ROM so someone else can check it.
dan.florian.mihai
Postby dan.florian.mihai » 21.03.26, 05:20
I've added it into a zip file, thank you kindly
ROM.zip
(486.87 KiB) Downloaded 121 times
SGdata
Postby SGdata » 21.03.26, 11:53
Your ROM is fine.
italyassistance
Postby italyassistance » 06.04.26, 15:00
bad heads or bad surface, try donor heads.
protech
Postby protech » 22.08.26, 10:38
italyassistance wrote:Source of the post FAIL Servo Op=0100 Resp=0003
I have the same drive ST2000LM007-1R8174 here. I read the ROM using a programmer and unlocked. But the drive still gives "BootCode is locked! Use programmer for ROM reading!". I got access to user files and i am copying files but extreemly slow. I need to speed up the process please. Unlocking the ROM on WD drives using PC3k is straight forward. May be i didn't do the unlocking right? This is terminal and log
Boot0x80M
TCC:001D
Rst0x80M
T:0x000D 0x278454DE
FTU
TCC:001D:0020 EMCDataErr:00000014
PrgF
(P)SATAReset
RAWOFF
PASS
Primaryislatest!-00000001
[MCMTW_DSW]Secondary-00102825Out:
InitiateMarkPendingReallocateRequestfordisc_lba:001D42D18ACHS:0000E35F.02.0013
PrgF!
DSC PASSOut:
InitiateMarkPendingReallocateRequestfordisc_lba:001D42F188CHS:0000E375.02.0067
PrgF!
PrgF
6GbMaxSpeedloweredto3GbforIntelbug
SendStatus:COMRESETseen
CSpd=1.5Gbps
FIS34
StartingLBAofRWRequest=001D4A8E58Length=00000027
ProcessRWError-Read-atLBA001D4A8E58SenseCode=43160080Out:
SP Regen FAIL
SPRegen[0000|43160080]@LBA=0x1D4A8E58Out:
InitiateMarkPendingReallocateRequestfordisc_lba:001D4A8E58CHS:0000E8BF.02.003F
PrgF
PrgF!
[MCMTW_DSW]Primary-00102826
IDLE1
VC0
XI2
VC1
VC2Up
IDLE2
VC0
VC1
VC2Up
XI2
TCC:001D:0020 EMCDataErr:00000000
italyassistance
Postby italyassistance » 22.08.26, 17:55
Why u read a rom with programmer? u dont have a Ace Pc usb terminal 3?
