ST2000DM008
davidswa1
ST2000DM008
Postby davidswa1 » 31.01.25, 21:36
Hello, I have a ST2000DM008 that needs a head swap. It appears these specific models come in 1 and 2 platters. I found that out after purchasing a donor that was manufactured within one week of the patient drive. My bad. The patient has two platters and three heads. The donor has one platter and two heads. Does anyone know if there is a method to tell the difference between the two from the labels? The part numbers are the same on both. Thanks, Dave Sr.
Re: ST2000DM008
Postby AJ2008 » 20.02.25, 11:21
What is serial number from both patient and donor?
peter.best
Re: ST2000DM008
Postby peter.best » 03.03.25, 08:34
PCB number?
Re: ST2000DM008
Postby AJ2008 » 13.03.25, 17:53
PCB number I imagine will be same. I mean serial number from HDD label or base
Users browsing this forum: Bing [Bot] and 6 guests
