hello guys
i saved important sis files and regenerated the translator but sectors can be readed only with utility mode "very slow speed"
does someone know how to solve this problem?
ST8000DM004 can read sector only under utility mode HELP
- datasalvage
Re: ST8000DM004 can read sector only under utility mode HELP
Which was the cause for TA regeneration?
datasalvage wrote:Source of the post i saved important sis files and regenerated the translator
I’m pretty sure your drive is SMR…. That might not have been a good idea.
- datasalvage
faulty heads i guess..... customer was happy with partial data recovery
datasalvage wrote:fauly heads i guess..... customer was happy with partial data recovery
So, as I understand, u have read the disk partially, by utility, and the cause for TA regeneration was "faulty heads"....
Did u swap/replace the heads ? Was the translator readable after regeneration ?
I am just trying to figure out the case.
- datasalvage
i already forgot but i think the customer was happy with partial data recovery !can you suggest a good scissors for cuut off fauly heads? i tried nail scissors but i damaged all heads
- gameboybin
- New user
I am having same exact issue.
ST1000VX005-2EZ102 heads are dead.
Swapped the heads, unlocked the drive, from the start the drive has some problems with fw. Although through the sector read the data was visible, however just saving modules will make the drive hang and goes to BSY mode. and i tried reading the drive without any settings. The drive goes through like 3-5gb/30mb/s normally until it gets those yellow + black dotted lines. I stopped the procces.
I tried backup modules then rebuilding translator. Upon starting the drive up the drive would again read normally in UDMA mode for 4-5GB then again starts those yellow black dotted sectors. I changed to read from utility. Even though the speeds are slow, at least it still gets the data
Hi guys,
Have a ST8000DM004 here. Spins up and keeps going and no funny sounds. No ID and stays busy. The blog for "No HOST FIS-ReadyStatusFlags" is only for non SMR drives so didn't want to go that route. Have attached the screen shot. can you please advise?
