I have the disk:
ST2000LM007 SITE: WU FW: EB01 PN: 1R8174-57
It spins normally, After power on it the terminal shows the following error ONLY no any other text:
LED:0x000000BB FAddr:0x00004300 error
I cannot patch it, I read the Rom via reader and patched it, then copied again to the Original Rom, same result
Any one have an idea about what is happening
thank you
Rosewood_AF , LED:0x000000BB FAddr:0x00004300 error
- Masterclass
Re: Rosewood_AF , LED:0x000000BB FAddr:0x00004300 error
Do you use recent utility version?
yes, 7.3.17 version
Hope Ace Ts have an idea bout this issue
- Masterclass
recent is 7.4. You need to patch rom image using a recent utility ver
I will prepare to have new TS contract, but i need someone to patch it for me with the new version... if you can ,
TS AT ACE patched for me the rom with 7.4 versuon ( thank you). But same error appears...
Hello dear
I also see the LED BB error in the terminal. Of course, my hard drive is ST6000NM0115.
If you find a solution, I would appreciate it if you could share it with me.
Thank you
Thank you
