Hello guys hows your new year?
i received this drive that doesnt spin at all and stay BSY with error LED:0x000000BD FAddr:0x000059D8
iv tried the official guide https://blog.acelab.eu.com/how-to-fix-a ... -chip.html
but with donor PCB "after Repeat the unlocking steps (1-6) " i cannot enter the command OI1 ..... i will get LED:0x000000BD FAddr:0x000059D8 !AGAIN
and if i skip this command and Repeat the unlocking steps (7-9). the drive spinds but i get Waiting drive spin up ! therefore i cannot use the terminal !
with original PCB is the same.....the drive spins if i change to 82 34 56 78 but i cant enter the command OI1
i also noticed that nomatter how many times i write the patient rom into DONOR PCB it will show the SN of the DONOR.........
any help will be very very helpfull
ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE
- datasalvage
- lifeguarddata
Re: ST2000LX001 LED:0x000000BD FAddr:0x000059D8 HELP PLEASE
this is Hybrid Drive.
- ajay.mudhgill
datasalvage wrote:Source of the post nomatter how many times i write the patient ro
I just did one of these just over a week ago. I wouldn’t worry about the incorrect passport
- datasalvage
ajay.mudhgill wrote:Source of the post i can help u
hello sir how can yoou help me ?
- datasalvage
osity wrote:Source of the postdatasalvage wrote:Source of the post nomatter how many times i write the patient ro
How did you solved the problem Sir?can you suggest some trick? the patient drive has same pcb numer.same model and same firmware
- datasalvage
can somebody tell me which is the correct position for the read channell? i tried many times but is still get the error LED:0x000000BD FAddr:0x00008004
should i short before or after the tech Unlock Handshake"?
should i keep the position untill the drive get ready ? if the position is correct will the drive keep spinning or will stop spins?
Those above contacts are for the motor. Are you trying to short the motor? Short after initialization. You may want to incorporate a paperclip into your tweezers. There should be a blog post that should help you with this also.
