100535704-Seagate Short pins
The Seagate PCB no. 100535704 once connected to PC-3000 remains in busy state. Please suggest a solution. Also provide shortening points of the said Seagate PCB. Thank you.
- digitalsupport
- User
Re: 100535704-Seagate Short pins
Would be easier to help you if you post model and terminal output.
For shorting points use search in forum - shorting is not a universal solution and can cause data loss if you don´t know whats wrong with the drive.
