PC3000 EXPRESS Version 6.9.16
I am trying to patch the lock because the sector cannot be accessed.
In order to patch, you need to read the ROM with a terminal.
Can't read rom with terminal
The following message is output.
I've tried all the terminal read speeds. The same error message is output.
DOM : 23AUG2021
PCB : 100870309 REVA
log
Software can`t control COM port signal level for this USB/COM adapter
HDD family detecting...
Family ID: CF
WARNING! Unknown family!
Model by ID............................. : ST5000LM000-2U8170
Tech Key...
Requesting FW Pkg ver ........ M2AEA13B0.SDM4.410013.0001
Detecting SA Phys Sct Size...
Can not detect SA phys secotr size by ATA!
Terminal
ASCII Diag mode
F3 T>
Bad cmd: 0x0303
How I've tried so far
- BOOT CODE mode on startup
- Read 3.3v, 2.5v, 1.8v rom with terminal 3
I need an unlock patch, but I can't read the rom. Is there any other way?
(rewrite) ST5000LM000-2U8170 2.5 HDD ROM Read Problem Asking for Help
Re: (rewrite) ST5000LM000-2U8170 2.5 HDD ROM Read Problem Asking for Help
If you haven't done it already, try isolating head contacts and try again. This has worked in the past with similar problem.
