ST1000DM003 - Worked at first but now just spins and stays in BSY
murphman
Postby murphman » 02.11.18, 17:53
I need some help. I got a ST1000DM003 which came in with bent heads. I replaces the heads and the drive recognized (took a little longer but under 10 seconds) and I got logical access. Managed to pull of a few PST files and some other data. However, the drive hit a bad sector and power cycled. Now it just spins and stays in BSY. I tried editing SMP flags in 93 sys file. Copy 0 wouldnt read but Copy 1 did. I copied Copy 1 onto Copy 0 successfully and unchecked everything (as per blog and many other drives I fixed this way). I power cycled the drive but it still just spins and stays in BSY (i double checked and the 93 changes are saved). I am at a loss and dont know what else to do... please help. Here is the terminal output, thank you:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Spin Up
SpinOK
TCC:0025
RECOV Servo Op=0900 Resp=0005
SIM Error 2041 LBA 0000000000090AAD FD FC358028
RW Error 43110081
MCMainPOR: Start:
User Data Base 0043F2A8
Check MCMT Version: Factory Init
MCInitialize: Start: Host VBM Size (Bytes): 00000210 Metadata VBM Size (Bytes):
ClearMC: Start Full Starting LBA 0000CC80, Count 00432628S23(01)S21(02)S21(03)S21(04)S21(05)S23(06)S21(07)S23(08)S23(09)S21(0A)S21(0B)S23(0C)S23(0D)S21(0E)S23(0F)S23(10)S21(11)S21(12)S23(13)S21(14)S23(15)S21(16)S21(17)S21(18)S21(19)S21(1A)S21(1B)S21(1C)S23(1D)S21(1E)S21(1F)S21(20)S21(21)S21(22)S23(23)S23(24)S21(25)S23(26)S21(27)S21(28)S21(29)S21(2A)S21(2B)S21(2C)S21(2D)S21(2E)S21(2F)S21(30)S23(31)S21(32)S21(33)S21(34)S21(35)S21(36)S21(37)[0000000000001FED]v00000008qDUv00000008qDv00000008qDv00000008qDv00000008qDv00000008qDUv00000008qDv00000008qDv00000008qDU
LPC Disc Xfr: EXCEPTION: ProcessRWError: Status =00000002
Next Accessed LBA = 00001FED
Retry LBA = 00001FED
Retry Level = 00000000
Starting LBA of RW Request=0000001990 Length=000864C5
ProcessRWError -Write- at LBA 0000001FED Sense Code=C4030088S21(01)S21(02)S21(03)S23(04)S23(05)S21(06)S21(07)S23(08)S23(09)S21(0A)S21(0B)S21(0C)S21(0D)S23(0E)S21(0F)S23(10)S21(11)S21(12)S21(13)S21(14)S21(15)S21(16)S21(17)S21(18)S21(19)S21(1A)S21(1B)S21(1C)S23(1D)S21(1E)S21(1F)S21(20)S23(21)S21(22)[WA]!
ClearMC: Completed, Last LBA 000043F2A8
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS] Tail/Head 0000 0000
MCInitialize: Init complete:
MCMainPOR: MCTStateFlags 00000022 MCStateFlags 00000041 Tms 000045F8 PASS
SP200: MSPMainPOR Start
Starting LBA of RW Request=0000000000 Length=00000198
ProcessRWError -Read- at LBA 0000000000 Sense Code=43110081
ERC TO exceeded, orig value in us:FFFFFFFF
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000000
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000000
MSP Reconstruction: EXCEPTION: Read MSP Segment Error
Segment 0000 StartLBA 00000000 ErrorLBA 00000000
Error in MSP Header
Continue MSP Read, PreError Segment Cnt0000
Num Segments 0066
Starting LBA of RW Request=0000000004 Length=00000194
ProcessRWError -Read- at LBA 0000000004 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000004
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000001
Segment 0001 StartLBA 00000020 ErrorLBA 00000020
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000008 Length=00000190
ProcessRWError -Read- at LBA 0000000008 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000008
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000002
Segment 0002 StartLBA 00000040 ErrorLBA 00000040
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=000000000C Length=0000018C
ProcessRWError -Read- at LBA 0000000016 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000016
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000003
Segment 0005 StartLBA 000000A0 ErrorLBA 000000B0
Error in MSP data
Continue MSP Read, PreError Segment Cnt0002
Num Segments 0066
Starting LBA of RW Request=0000000018 Length=00000180
ProcessRWError -Read- at LBA 0000000018 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000018
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000004
Segment 0006 StartLBA 000000C0 ErrorLBA 000000C0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=000000001C Length=0000017C
ProcessRWError -Read- at LBA 0000000024 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000024
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000005
Segment 0009 StartLBA 00000120 ErrorLBA 00000120
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000028 Length=00000170
ProcessRWError -Read- at LBA 0000000028 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000028
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000006
Segment 000A StartLBA 00000140 ErrorLBA 00000140
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=000000002C Length=0000016C
ProcessRWError -Read- at LBA 0000000031 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000031
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000007
Segment 000C StartLBA 00000180 ErrorLBA 00000188
Error in MSP data
Continue MSP Read, PreError Segment Cnt0001
Num Segments 0066
Starting LBA of RW Request=0000000034 Length=00000164
ProcessRWError -Read- at LBA 0000000034 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000034
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000008
Segment 000D StartLBA 000001A0 ErrorLBA 000001A0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000038 Length=00000160
ProcessRWError -Read- at LBA 000000006C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000006C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000009
Segment 001B StartLBA 00000360 ErrorLBA 00000360
Error in MSP Header
Continue MSP Read, PreError Segment Cnt000D
Num Segments 0066
Starting LBA of RW Request=0000000070 Length=00000128
ProcessRWError -Read- at LBA 00000000D4 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 000000D4
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000A
Segment 0035 StartLBA 000006A0 ErrorLBA 000006A0
Error in MSP Header
Continue MSP Read, PreError Segment Cnt0019
Num Segments 0066
Starting LBA of RW Request=00000000D8 Length=000000C0
ProcessRWError -Read- at LBA 00000000E9 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 000000E9
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000B
Segment 003A StartLBA 00000740 ErrorLBA 00000748
Error in MSP data
Continue MSP Read, PreError Segment Cnt0004
Num Segments 0066
Starting LBA of RW Request=00000000EC Length=000000AC
ProcessRWError -Read- at LBA 00000000EC Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 000000EC
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000C
Segment 003B StartLBA 00000760 ErrorLBA 00000760
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=00000000F0 Length=000000A8
ProcessRWError -Read- at LBA 00000000F3 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 000000F3
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000D
Segment 003C StartLBA 00000780 ErrorLBA 00000798
Error in MSP data
Num Segments 0066
Starting LBA of RW Request=00000000F4 Length=000000A4
ProcessRWError -Read- at LBA 00000000F6 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 000000F6
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000E
Segment 003D StartLBA 000007A0 ErrorLBA 000007B0
Error in MSP
Num Segments 0066
Starting LBA of RW Request=00000000F8 Length=000000A0
ProcessRWError -Read- at LBA 00000000F8 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 000000F8
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000000F
Segment 003E StartLBA 000007C0 ErrorLBA 000007C0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=00000000FC Length=0000009C
ProcessRWError -Read- at LBA 00000000FD Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 000000FD
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000010
Segment 003F StartLBA 000007E0 ErrorLBA 000007E8
Error in MSP
Num Segments 0066
Starting LBA of RW Request=0000000100 Length=00000098
ProcessRWError -Read- at LBA 0000000100 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000100
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000011
Segment 0040 StartLBA 00000800 ErrorLBA 00000800
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000104 Length=00000094
ProcessRWError -Read- at LBA 0000000104 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000104
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000012
Segment 0041 StartLBA 00000820 ErrorLBA 00000820
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000108 Length=00000090
ProcessRWError -Read- at LBA 000000010A Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000010A
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000013
Segment 0042 StartLBA 00000840 ErrorLBA 00000850
Error in MSP data
Num Segments 0066
Starting LBA of RW Request=000000010C Length=0000008C
ProcessRWError -Read- at LBA 000000010C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000010C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000014
Segment 0043 StartLBA 00000860 ErrorLBA 00000860
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000110 Length=00000088
ProcessRWError -Read- at LBA 0000000110 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000110
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000015
Segment 0044 StartLBA 00000880 ErrorLBA 00000880
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000114 Length=00000084
ProcessRWError -Read- at LBA 0000000114 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000114
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000016
Segment 0045 StartLBA 000008A0 ErrorLBA 000008A0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000118 Length=00000080
ProcessRWError -Read- at LBA 0000000118 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000118
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000017
Segment 0046 StartLBA 000008C0 ErrorLBA 000008C0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=000000011C Length=0000007C
ProcessRWError -Read- at LBA 0000000123 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000123
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000018
Segment 0048 StartLBA 00000900 ErrorLBA 00000918
Error in MSP data
Num Segments 0066
Starting LBA of RW Request=0000000124 Length=00000074
ProcessRWError -Read- at LBA 0000000124 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000124
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000019
Segment 0049 StartLBA 00000920 ErrorLBA 00000920
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000128 Length=00000070
ProcessRWError -Read- at LBA 0000000128 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000128
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000001A
Segment 004A StartLBA 00000940 ErrorLBA 00000940
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=000000012C Length=0000006C
ProcessRWError -Read- at LBA 000000012C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000012C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000001B
Segment 004B StartLBA 00000960 ErrorLBA 00000960
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000130 Length=00000068
ProcessRWError -Read- at LBA 0000000130 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000130
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000001C
Segment 004C StartLBA 00000980 ErrorLBA 00000980
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000134 Length=00000064
ProcessRWError -Read- at LBA 0000000137 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000137
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000001D
Segment 004D StartLBA 000009A0 ErrorLBA 000009B8
Error in MSP
Num Segments 0066
TCC:0025
Starting LBA of RW Request=0000000138 Length=00000060
ProcessRWError -Read- at LBA 0000000138 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000138
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000001E
Segment 004E StartLBA 000009C0 ErrorLBA 000009C0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=000000013C Length=0000005C
ProcessRWError -Read- at LBA 000000013C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000013C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000001F
Segment 004F StartLBA 000009E0 ErrorLBA 000009E0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000140 Length=00000058
ProcessRWError -Read- at LBA 0000000140 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000140
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000020
Segment 0050 StartLBA 00000A00 ErrorLBA 00000A00
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000144 Length=00000054
ProcessRWError -Read- at LBA 0000000144 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000144
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000021
Segment 0051 StartLBA 00000A20 ErrorLBA 00000A20
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000148 Length=00000050
ProcessRWError -Read- at LBA 000000014A Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000014A
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000022
Segment 0052 StartLBA 00000A40 ErrorLBA 00000A50
Error in MSP
Num Segments 0066
Starting LBA of RW Request=000000014C Length=0000004C
ProcessRWError -Read- at LBA 000000014C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000014C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000023
Segment 0053 StartLBA 00000A60 ErrorLBA 00000A60
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000150 Length=00000048
ProcessRWError -Read- at LBA 0000000150 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000150
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000024
Segment 0054 StartLBA 00000A80 ErrorLBA 00000A80
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000154 Length=00000044
ProcessRWError -Read- at LBA 0000000154 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000154
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000025
Segment 0055 StartLBA 00000AA0 ErrorLBA 00000AA0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000158 Length=00000040
ProcessRWError -Read- at LBA 000000015A Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000015A
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000026
Segment 0056 StartLBA 00000AC0 ErrorLBA 00000AD0
Error in MSP
Num Segments 0066
Starting LBA of RW Request=000000015C Length=0000003C
ProcessRWError -Read- at LBA 000000015C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000015C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000027
Segment 0057 StartLBA 00000AE0 ErrorLBA 00000AE0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000160 Length=00000038
ProcessRWError -Read- at LBA 0000000160 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000160
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000028
Segment 0058 StartLBA 00000B00 ErrorLBA 00000B00
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000164 Length=00000034
ProcessRWError -Read- at LBA 0000000164 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000164
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000029
Segment 0059 StartLBA 00000B20 ErrorLBA 00000B20
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000168 Length=00000030
ProcessRWError -Read- at LBA 0000000168 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000168
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000002A
Segment 005A StartLBA 00000B40 ErrorLBA 00000B40
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=000000016C Length=0000002C
ProcessRWError -Read- at LBA 000000016C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000016C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000002B
Segment 005B StartLBA 00000B60 ErrorLBA 00000B60
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000170 Length=00000028
ProcessRWError -Read- at LBA 0000000171 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000171
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000002C
Segment 005C StartLBA 00000B80 ErrorLBA 00000B88
Error in MSP
Num Segments 0066
Starting LBA of RW Request=0000000174 Length=00000024
ProcessRWError -Read- at LBA 0000000174 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000174
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000002D
Segment 005D StartLBA 00000BA0 ErrorLBA 00000BA0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000178 Length=00000020
ProcessRWError -Read- at LBA 000000017A Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000017A
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000002E
Segment 005E StartLBA 00000BC0 ErrorLBA 00000BD0
Error in MSP
Num Segments 0066
Starting LBA of RW Request=000000017C Length=0000001C
ProcessRWError -Read- at LBA 000000017C Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000017C
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 0000002F
Segment 005F StartLBA 00000BE0 ErrorLBA 00000BE0
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000180 Length=00000018
ProcessRWError -Read- at LBA 0000000180 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000180
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000030
Segment 0060 StartLBA 00000C00 ErrorLBA 00000C00
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000184 Length=00000014
ProcessRWError -Read- at LBA 000000018E Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 0000018E
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000031
Segment 0063 StartLBA 00000C60 ErrorLBA 00000C70
Error in MSP data
Num Segments 0066
Starting LBA of RW Request=0000000190 Length=00000008
ProcessRWError -Read- at LBA 0000000190 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000190
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000032
Segment 0064 StartLBA 00000C80 ErrorLBA 00000C80
Error in MSP Header
Num Segments 0066
Starting LBA of RW Request=0000000194 Length=00000004
ProcessRWError -Read- at LBA 0000000196 Sense Code=43110081
MSP LPCDiscXfrScratchPadSegment detected ERROR: StateFlags 00000600 DiscLBA 00000196
MSP Reconstruction: EXCEPTION: Read ScratchPad Section 00000033
Segment 0065 StartLBA 00000CA0 ErrorLBA 00000CB0
Error in MSP data
Num Segments 0066
MSP MainPOR: 00003000 Tms 000045F8 000113C1 00015A60
MSP MainPOR: Complete
No HOST FIS-ReadyStatusFlags 0002A1A1
TCC:0025
pclab
Re: ST1000DM003 - Worked at first but now just spins and stays in BSY
Postby pclab » 02.11.18, 19:12
Probably you have media damage...
GuideRecovery
Postby GuideRecovery » 03.11.18, 10:33
do you have backup of sysfiles ? if media is not damage probably can be solved.
Wasim Zafar
https://mindmergepk.com
murphman
Postby murphman » 05.11.18, 18:08
Unfortunately I didn't get a chance to do a backup; given the original heads were bent I wanted to grab the most important data first when I got logical access (which I did) before the heads potentially failed. There is just a little more data I would like to pull of the drive though.
I can still view and access all the sys files through "service information objects"
Postby DataMedics » 06.11.18, 22:06
Did you try disabling everything in system file 93?
fastec
Postby fastec » 27.05.21, 17:57
Bring up this topic since I have seen it a couple of times
This is a weak weak weak head
Just make heads map change in ROM and you'll see it
Though just wait (so long) and if you edited SMP module, it could go DRD DSC, but then, you are at the same point above
Better start testing heads one by one
FAsTec is the owner of the Italian popular brand RecuperoDati299
https://www.RecuperoDati299euro.it
