ST1000LM035-1RK172 patched - no user access (abort)
positivebit
Postby positivebit » 01.05.20, 16:24
patched rom in Rosewood utility, HDD ID fixed, backup resources 98% sucesfully.
power off/on, patch, ask secotors (any)
Terminal show:
Boot 0x80M
Tech Unlock Handshake: 0xCCD9DED1
Reply:
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
DSC PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
ABORT!
OpCode = 00000024
SenseCode = 03310003
ReadyStatusFlags = 0002A1A1
ABORT!
OpCode = 00000024
Unrecoverable Read Verify Error Reported
k4z1
Re: ST1000LM035-1RK172 patched - no user access (abort)
Postby k4z1 » 05.05.20, 08:34
Does the drive give correct ID?
Which modules are corrupted?
Filipp_TS
Postby Filipp_TS » 15.05.20, 10:38
Based on terminal report drive has Translator issue.
If case is an actual please contact Technical support - ts.acelab.eu.com
