hi
i have rosewood 1tb bad heads replaced new heads then drive gives 0capacity i have 2b and28 modules rewrited module 2b still 0 mb
i tried regen translator in terminal i got error.
DOS:0 Scan Unit
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
RECOV Servo Op=01A5 Resp=0005
RECOV Servo Op=00A5 Resp=0005
RECOV Servo Op=0095 Resp=0005
RECOV Servo Op=06DF Resp=0005
DSC
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
RECOV Servo Op=0195 Resp=0005
DiagError 0000500EProcess Defect List Error
R/W Sense 00000002, R/W Error 041C0087, List Offset 00000000, List Index 00000000, File Error 00000000
F3 T>
any suggestions Pls....
Seagate 1TB Rosewood
- CS DATA RECOVERY
Regards,
PAVAN KUMAR
CS DATA RECOVERY
PAVAN KUMAR
CS DATA RECOVERY
Re: Seagate 1TB Rosewood
CS DATA RECOVERY wrote:Source of the post any suggestions Pls....
Yeah, don't rush to use an M command so quickly on the next case. I hope you made a full backup of the system files first.
- CS DATA RECOVERY
yes sir i have taken backup all only 348 is missed actually i tried to restore 2b restored but not helped then i dont have another option thats why i did M comand
how can i solve it sir ..
Regards,
PAVAN KUMAR
CS DATA RECOVERY
PAVAN KUMAR
CS DATA RECOVERY
ONE HEAD BAD
REPLACE HEAD AFTER POSSIBLES DATA
Best regards,
Vijayan MBA
Raminfotech Data Recovery
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Vijayan MBA
call 7092114411/22
vijayan wrote:Source of the post ONE HEAD BAD
On Basis Is Your Observation Based On Boss ,Can You Elaborate Please .Pavan Always check if your drive can write well on a unimportant module before you try stuff like this .Might be there is platter damage too
