ST3320418AS - strange case
AdasRip
Postby AdasRip » 20.10.18, 10:11
Hello. I've patient ST3320418AS.
At the beginning the patient became ready but did not return HDD ID.
In the terminal, he reported as follows:
Code: Select all
Rst 0x10M
Servo Processor Is Reset.
ExecuteSpinRequest
(P) SATA Reset
I have cleaned the HDA connectors then HDD starts and get at the DRD and DSC status for a few of a second. Next get BSY status for a few seconds and over and over again.
So I 've uncheck background processes in Edit HDD ID. Then patients starts normally and return HDD ID corectly.
Unfortunately, there are problems with accessing user data. It is possible to read about 1% of sectors. With the others, the drive reboots immediately.
I was able to read the data from Active PC-3000 Utility. The reading speed is only 10 KB/s, but it's better than not at all.
Thus, the data is currently being recovered but I wanted to ask for educational purposes, what is the reason that the data is recovered only from Active PC-3000 Utility?
unspoken
Re: ST3320418AS - strange case
Postby unspoken » 21.10.18, 19:44
My bet translator problem.
Postby AJ2008 » 22.10.18, 09:19
Short read channels during calibration to try to retain T> and make more tests from there.
