rosewood drive ABR detected
majid-nazeri
Postby majid-nazeri » 28.12.17, 08:07
Hi Dears ,
the rosewood drive ABR detected and hasnt any ID and I cant write sys files via ATA(direct or indirect) and terminal after unlock, please give me a solution ,
thanks a lot
Masterclass
Re: rosewood drive ABR detected
Postby Masterclass » 28.12.17, 12:05
MC must be faulty
Postby AJ2008 » 28.12.17, 14:03
The status register shows DWF flag - this is common symptom of damage to MC and often this error is presented during attempts to work over ATA.
You need to work over terminal only - save important modules including translator, clear translator which will rebuild MC, restore translation system via the backup taken before the translator regeneration.
Masterclass
Postby Masterclass » 29.12.17, 09:20
AJ2008 wrote:Source of the post clear translator which will rebuild MC, restore translation system via the backup taken before the translator regeneration
My advice is: If you need data - DO NOT do this.
Postby Amarbir[CDR-Labs] » 31.12.17, 04:39
Masterclass wrote:Source of the post
Correct my advise to him would be reach terminal and then check defect list he will note its overfull with defects he needs to clear it in terminal ,Then reach c level and work with MC and Also Reach level 7 and work with dos config level clear it .
PS : in few cases i have seen you cannot take a backup of anything until you do this :D
Postby AJ2008 » 09.01.18, 10:46
Why would you advise this? MC is part of translator so it cannot be cleared without loosing access to data, but retaining original copy of translator module (which includes MC defects) for restoration after repair will prevent this.
Masterclass
Postby Masterclass » 10.04.18, 07:46
Do you know the diferrence between MediaCache and MC Table?
AJ2008 wrote:Source of the post (which includes MC defects)
Which defects??
Filipp_TS
Postby Filipp_TS » 10.04.18, 21:35
Masterclass wrote:Source of the post Which defects??
Which are related to MediaCache area.
jojo2012
Postby jojo2012 » 23.04.18, 13:07
majid-nazeri wrote:Source of the post Hi Dears ,
thanks a lot
majid-nazeri- Did you solve?....I have the same problem.
Postby AJ2008 » 23.04.18, 13:50
jojo2012 wrote:Source of the post
thanks a lot
Is this the same case from the other post you made? You have not solved yet? Contact me at skype and I will help you more if you need it :)
jojo2012
Postby jojo2012 » 23.04.18, 16:05
thanks a lot
Yep, sent PM
Nick_TS
Postby Nick_TS » 24.04.18, 20:47
AJ2008 wrote:Source of the post Why would you advise this? MC is part of translator so it cannot be cleared without loosing access to data, but retaining original copy of translator module (which includes MC defects) for restoration after repair will prevent this.
Unfortunately, translator regeneration clears entries in MC system file and 90 GB of Media Cache area. We can write back the MC system file, but can't write back content of MC area.
Rosewood drives use write-back media cache approach, where data is stored in the MC only, and transfer blocks from MC to user area is performed when new cache blocks appear.
If we clear the MC zone we can lost the latest timestamped data on the drive (for long ago several months)
Postby AJ2008 » 27.04.18, 09:32
Translator is built with these MC defects included, so restoration of original translator table (where these MC entries are written) should restore access to lost data
Users browsing this forum: Bing [Bot] and 10 guests
