Rosewood with calibration issue...
Paradog84
Postby Paradog84 » 26.10.17, 21:59
I have a Rosewood Seagate, 2Tb with 2 platters...
Reading is completely error free except it is slow with the constant terminal message -
RECOV Servo Op=0295 Resp=0005
etc...
Drive is not making any clicking sounds at all, even after moving both platters into a donor HDA (without removing heads)
Motor was balanced & platters aligned - drive is vibration free.
This message seems to only appear when reading, from experience this tells me the read adaptives need to be imported from the donor - but this is not supported on Rosewood up to date?
carlosmar
Re: Rosewood with calibration issue...
Postby carlosmar » 27.10.17, 15:03
Hi, You should wait a bit after power on, maybe start reading from SA, If not, need to find another heads donor. Be carefully when swap heads.
Nick_TS
Postby Nick_TS » 27.10.17, 17:56
Did you try to short read channels to access the terminal prompt?
Paradog84
Postby Paradog84 » 28.10.17, 12:58
Hi, thanks for your replies...
No, I did not short the read channels, I've never done this with Rosewood family - the drive becomes ready and I can access the SA/Data areas as normal.
Only when reading user data does this message appear.
Postby Amarbir[CDR-Labs] » 20.12.17, 00:09
Dmitriy_TS wrote:Source of the post Hello,
Dimitry ,
In What Situations In Rosewood Do You Advice This .
