Hello Guys,I've a USB seagate ST2000LM005, and i'm searching the donor sata pcb.
The Marvell Chip is 88i1025 and the number of usb pcb is 100765396 REV A
Thank you for the help.
ST2000LM005 Donor pcb
- DataMedics
Re: ST2000LM005 Donor pcb
I've got a list of SATA compatible USB PCB replacements that I've been keeping here: https://www.data-medics.com/forum/samsu ... t1438.html
However, that one is still on the "unconfirmed" list. So it's a pairing I found mentioned somewhere, but have never actually confirmed that it works myself.
i've see your list and i've buy the unconfirmed pcb 100731207.
The unconfirmed board isn't compatible with usb pcb.
I did the test today.
After a bit of research I found a compatible pcb. Be No. 100767980. After I'm Shipped, I'll Test You Will Confirm About PCB Compatibility
The sata pcb 100767980 is compatible with usb pcb 100765396
- DataMedics
asocla wrote:Source of the post The sata pcb 100767980 is compatible with usb pcb 100765396
Thanks! I added that pairing to my running list.
