The error messages we see in the terminal view is:
Code: Select all
Rst 0x20M
No HOST FIS-ReadyStatusFlags 2002B001
At this point we decide to replace the controller board with a new one (same ID, it worked fine when connected to PC3000 without disk). As written into the documentation we have move the ROM chip from the damaged board to the new one.
Before connecting the new board to the disk we tried again to power on only the board with the PC3000 but we had again the same error message. Now we are quite sure that the problem is the ROM.
What do you think? What can we try now?
Thanks...
