PLS SHARE LDR FOR ST1000DM003 FW:CC43
CS DATA RECOVERY
Postby CS DATA RECOVERY » 08.11.16, 10:35
Dear Friends ,
can u pls share LDR for Seagate ST1000DM003 FW:CC43
Thank
Pavan
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Re: PLS SHARE LDR FOR ST1000DM003 FW:CC43
Postby Amarbir[CDR-Labs] » 08.11.16, 13:49
Pavan,
Why d you need a loader for this ?
CS DATA RECOVERY
Postby CS DATA RECOVERY » 08.11.16, 14:29
Hi , Amarbir
drive capacity shows correct serial no 0000000,wrong model , no fw version
no terminal access i tried shorting process then got terminal access
i tried smart , i tried nrg list ,i tried translator recovery & and tranlator regenrator
no result
thats why i need to uplaod LDR
Pavan
Regards,
PAVAN KUMAR
CS DATA RECOVERY
CS DATA RECOVERY
Postby CS DATA RECOVERY » 08.11.16, 14:37
if i give a V1 command i got error
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Postby DataMedics » 08.11.16, 18:47
Hmmm.... just a guess here, but was that drive at another company before it came to you? Looks suspect.
pclab
Postby pclab » 08.11.16, 23:43
ROM edited, most probably...
CS DATA RECOVERY
Postby CS DATA RECOVERY » 09.11.16, 07:47
hi
actually its a refurbished seagate drive .
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Postby DataMedics » 09.11.16, 23:12
CS DATA RECOVERY wrote:Source of the post hi
Ah! that's probably why it's so screwed up. Who knows what they did to "refurbish" it. Those tend to be nightmares.
CS DATA RECOVERY
Postby CS DATA RECOVERY » 10.11.16, 12:43
yes u write fake serial no fw i return the drive .
Thanks for sharing Data Medics :)
Regards,
PAVAN KUMAR
CS DATA RECOVERY
