I work for a data recovery lab and was experimenting with A Seagate ST3100528AS model with firmware CC44. Initially I could access some sectors at the end of the drive, but not at front. I ran a Format User Area after backing up the resources to see what it does. Now I can't access any sectors. Any way we can recover it with saved resources? I tried translator regeneration, which doesn't work.
Any ideas what a User Format Area does?
- DataMedics
Re: Any ideas what a User Format Area does?
As far as I'm concerned:
Service Area = Where Firmware is Stored
User Area = Where Data is Stored
Format User Area = Data Gone
I suppose it depends on how long you let it run for, if there's any data left now.
Although I have never tested that operation I have to agree with DataMedics. It probably does exactly what it says.
But, I copied this from Data-Medics forum and I guess you could get lucky if it's the operation that "not effect Data in a drive".
m0,2,2,,,,,22 ( Format user area partition without certifying defects and relocate defects. not effect Data in a drive )
m0,2,1,,,,,22 ( Format user area partition with user slip list with certify defects. DATA WILL BE LOSS )
m0,D,3,,,,,22 ( Format user area partition with repairing of bad sector, auto add bad sector into G list and in the last it will be shifted to P list )"
It was blank drive that I pulled out of the shelf, first I was going to do a wipe. But then I tried to see what it shows in terminal. I had access to some sectors at first, but after user format no access to the drive. It Id's still but the heads gave up. The heads were failing ...
This weekend I tested Tests > User commands > Format User Area on a Seagate 7200.12 ST3320418AS. It took 2 hours and when it completed the data was gone.
As soon as I clicked "Format User Area" a message popped up "This action will destroy user data! Continue?"
This is the terminal command that ran: T>m0,8,2,1,1,,,22
The drive still worked as expected when complete.
