RAM headmap editing problem
I have a ST4000DM000 which has an obviously bad head 3. I disabled that head in ROM using procedure as blog suggested and now drive is recognized properly. However, when I try to use any of the 3 RAM head map editing choices I get an error message: "Read ServoSym at Inx 0x0058 err=0x00000001". Can't proceed beyond this point. Any suggestions? Thanks.
- Amarbir[CDR-Labs]
Re: RAM headmap editing problem
msurgeon wrote:Source of the post I have a ST4000DM000 which has an obviously bad head 3. I disabled that head in ROM using procedure as blog suggested and now drive is recognized properly. However, when I try to use any of the 3 RAM head map editing choices I get an error message: "Read ServoSym at Inx 0x0058 err=0x00000001". Can't proceed beyond this point. Any suggestions? Thanks.
According To Me Once You Disable Head In ROM You just need to start DE After Seagate F3 Utility is started And Then Create a Headmap in DE .Then Disable The Head in De That Does Not Read ,Thats All About That
can you tell me please where is that one procedure on blog?......I have not found it.
Thanks so much
JoJo
