ace please explain rom adaptives - many unanswered questions
- DataMedics
Re: ace please explain rom adaptives - many unanswered questions
What were the original symptoms? Was the drive clicking and spinning down, or did it sound fairly normal on startup?
- cuumaytinh
- New user
DataMedics wrote:Source of the post What were the original symptoms? Was the drive clicking and spinning down, or did it sound fairly normal on startup?
some time it clicking and down. some time ít sound hear as normal but with noise sound.
I do not have solutions for the correct handling of this case . I just can say to clients that disk face scratched.
I has tried on two hard drives good and duplicity from each other and it runs very well .
- DataMedics
Have you tried ldr and dir upload to see if you can read the SA tracks from either head or even trough composite reading? Possibly it's just SA damage and you could recover by setting up a smart hot start drive.
- cuumaytinh
- New user
DataMedics wrote:Have you tried ldr and dir upload to see if you can read the SA tracks from either head or even trough composite reading? Possibly it's just SA damage and you could recover by setting up a smart hot start drive.
you can teach more about this? I really thank you for your reply.
- cuumaytinh
- New user
Rst 0x10M
MC Internal LPC Process
Spin Up
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
this log after change head. . has inporting adative head from rom donor hdd
Spin Up
cuumaytinh wrote:Source of the post smart hot start drive.
There is no hot-swap on Seagate F3 drives.
cuumaytinh wrote:it really is not clear. Sometimes I was change head from including model. P/N. First 3 numbers of S/N and producing contry. but failed
Its common that these drives suffer a head crash on one of the bottom platters out of sight. Check the heads under a microscope to see if they are dirty before trying the head swap.
If you put the patient heads back into the donor and the heads no longer work then you know that scratches killed the donor heads.
https://www.day1data.de
Skype: day1data
Skype: day1data
- DataMedics
Dmitriy_TS wrote:Source of the postcuumaytinh wrote:Source of the post smart hot start drive.
You're right, my mistake. I must have been going back and forth between a few threads and got confused which drive we were talking about.
Users browsing this forum: Bing [Bot] and 10 guests
