Error setting up protection block
Posted: 17.09.17, 16:45
by Bruno
Hi all,
i have here a ST9100828A with symptoms like pending bug.
Having try another PCB. - not succesful.
Swapping heads. - Same Problem.
Now i tryed "HDD initializion with head map changing in RAM", the result a window with *Error Setting up Protection Block*...
I think this was solved in prior Versions of DE, before any years??
Any sugestions?
Thanks for help
Bruno
Re: Error setting up protection block
Posted: 18.09.17, 09:00
by pclab
And what's the terminal log?
Posted: 18.09.17, 09:45
by Bruno
Hi pclab
Thankyou for answer.
Here is the terminal log after starting the util:
Interface task reset
4096k x 16 buffer detected
VENUS - 1_Disk S.01 02
Buzz - -17-06 17:08
Spin Ready
$($0084F,10C88,0000,00,5C,30,80)Switch to full int.
AM Reacquired
(P)$($10C7E,17C89,0000,02,63,50,86)Switch to full int.
AM Reacquired
$($01C9B,10C7E,0000,00,38,08,82)$($01C9B,10C7E,0000,00,3C,14,82)$($01C9B,10C7E,0000,00,3C,14,82)Switch to full int.
AM Reacquired
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
DiskAccess ReadSector EC=43 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
$($10CF0,10CBA,0000,01,42,10,8F)Switch to full int.
AM Reacquired
Failed sys sect. write
$($10CBA,10CEE,005C,00,90,10,81)Switch to full int.
AM Reacquired
PATA Reset
Master
Head Switch Timing Recalibration
AT Er 00 Nwt Er 37 RdWr 084af.02.00af
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 97f39ff7 be 97f39ff7.1.bd7 0000 005f 0000 d53c
DiskAccess ReadSector EC=43 at 0084af.02.00af
CE Log ErrCode=37 LBA=5f5dead Type=5DiskAccess ReadSector EC=43 at ffffffff.00.0060
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
DiskAccess ReadSector EC=43 at ffffffff.00.0248
AT Er 00 Nwt Er 43 RdWr 084af.02.0165
Niwot: 9ff79ff7 be 9ff79ff7.1.bd7 0000 005f 0000 d53c
DiskAccess ReadSector EC=43 at 0084af.02.0165
CE Log ErrCode=43 LBA=5f5df63 Type=5DiskAccess ReadSector EC=47 at ffffffff.00.0060
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
$($10CF9,0B8AD,006F,02,43,70,79)Switch to full int.
AM Reacquired
AT Er 00 Nwt Er 43 RdWr 084af.02.0167
DiskAccess ReadSector EC=43 at 0084af.02.0167
CE Log ErrCode=43 LBA=5f5df65 Type=5DiskAccess ReadSector EC=43 at ffffffff.00.0060
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
$($10D56,0B8AD,006F,02,43,70,68)Switch to full int.
AM Reacquired
$($1A2AD,0B8AD,006F,02,43,70,55)Switch to full int.
AM Reacquired
$($1A2F2,0B8AD,006F,02,43,6C,86)Switch to full int.
AM Reacquired
$($1A2AF,0B8AD,006F,02,43,6C,86)Switch to full int.
AM Reacquired
$($1A128,0B8AD,006F,02,43,6C,97)
When try head map changing in RAM:
Test : HDD initialization with head map changing in RAM
Test : HDD initialization by utility...
Switch HDD PWR supply.... : No
Terminal Reset........... : No
Terminal work speed...... : 921000
Used LDR................. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Momentus (Venus)\ST9100828A-3-ALA-5LZ0563D\Data\LDR\SgLDR.ldr
Loaded from.............. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Momentus (Venus)\ST9100828A-3-ALA-5LZ0563D\Data\LDR\SgLDR_Utl.ldr
Work with HDD through.... : ATA
App...................... : Loading from LDR
Used modifications....... : Fix 'Pending Bug'
Load Ovl 0............... : No
Initializing Safe Mode...
Switching HDD power supply ON
App patching...
Downloading App code...
App code downloading.................... : Error
SDLD : transmitted data size not aligned
terminal log when try load cert:
DiskAccess ReadSector EC=43 at ffffffff.00.00a4
INVALID Cert Disk Code - ROM Resident Revision Required: 3.ALA
T>Head Switch Timing Recalibration
Posted: 18.09.17, 14:30
by Bruno
Error after try a Task create, using loader (pending bug), see att. file
error.rtf
(2.58 MiB) Downloaded 582 times
Posted: 19.09.17, 12:36
by pclab
Have you checked heads?
It's doesn't seem you have the pending bug here....
Posted: 19.09.17, 13:25
by Bruno
Yes i having swapped the heads with same result. Also i changed the PCB, -with same Problem.
Posted: 19.09.17, 14:29
by pclab
Have you checked heads under microscope to check for media damage?
Posted: 19.09.17, 15:12
by Bruno
Yes shure, and i have tested the Patient heads in donor drive. Reading without Problem.
I think it is a Firmware Problem, but what??
e.g when i try to save the ROM, after a while i see this: Terminal : error switching to MOS
