Seagate ST3500413AS No HOST FIS-ReadyStatusFlags 2002A185
CS DATA RECOVERY
Postby CS DATA RECOVERY » 26.07.16, 11:53
Dear Friends ,
i have case Seagate ST3500413AS BSY
i tried solution No HOST FIS-ReadyStatusFlags (i have took the backup of modulesthen tried Translator regenerator then no result .
Head 1: entries 0 slips 0
Total Entries 1 Total Slips 0
F3 T>/
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
F3 T>
ASCII Diag mode
F3 T>/
F3 T>m0,6,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
F3 T>
any one suggestions pls...
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Re: Seagate ST3500413AS No HOST FIS-ReadyStatusFlags 2002A185
Postby DataMedics » 26.07.16, 16:20
Did you power cycle it and then try reading sectors afterward? I know this is probably a stupid question.
CS DATA RECOVERY
Postby CS DATA RECOVERY » 28.07.16, 12:51
CASE SOLVED
Regards,
PAVAN KUMAR
CS DATA RECOVERY
Postby Amarbir[CDR-Labs] » 31.07.16, 08:02
CS DATA RECOVERY wrote:Source of the post Hello,
Data Medics,
is it really stupid Question if you know solution give reply other wise leave it .
The problem solved my end.
Wow ,
What a Rude Answer To Such a Senior Data Recovery Expert ,Hats Off To You Sir Keep It Up :evil:
Return to “Arch ST10”
