Need Seagate Corsair ST9160827AS Ldr
jinarto
Postby jinarto » 26.10.18, 11:06
Dear all,
Thanks :D ,
Jinarto
Maxim_TS
Re: Need Seagate Corsair ST9160827AS Ldr
Postby Maxim_TS » 26.10.18, 15:56
Postby Amarbir[CDR-Labs] » 31.10.18, 17:35
Maxim ,
I have never had a case in seagate were i need to use a loader ,In TS and otherwise do they use these quite a lot and if yes in what scenarios
Postby AJ2008 » 01.11.18, 09:03
Amarbir[CDR-Labs] wrote:Source of the post
Maxim ,
Most common case would be 'Unable to Load Overlay' error in Seagate classic series
Maxim_TS
Postby Maxim_TS » 01.03.19, 09:19
AJ2008 wrote:Source of the post Most common case would be 'Unable to Load Overlay' error in Seagate classic series
The solution depends on drive condition. If heads are good, it might be possible to load the loader from same FW backup and get data access. More details about Old Seagate architecture are in manual in update box https://update.acelab.ru/
Return to “Arch ST10”
