LDR Needing for WD5000LPVX - FW 0006001T
Posted: 01.08.18, 08:11
by ankarakecis
Hi there,
please anybody have LDR of WD5000LPVX-22V0TT0 - FW 0006001T ,
THANKS.
Re: LDR Needing for WD5000LPVX - FW 0006001T
Posted: 02.08.18, 07:14
by northwind
Here you go
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>Read ROM................................ : Ok
>ROM Data size........................... : 256 Kb
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 94 400
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>ROM Modules:
>ROM version............................. : 06.1TJ
>ROM F/W version......................... : 0006001T
>Overlay F/W version..................... : 06.1UJ
>Servo F/W version....................... : NE.11
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
Posted: 02.08.18, 07:15
by northwind
11.rar
(443.74 KiB) Downloaded 344 times
