Need Resources for wd3200bevt-00zct0
michel
Postby michel » 12.09.14, 08:49
Need Resources for wd3200bevt-00zct0 (urgent) .Thanks
Re: Need Resources for wd3200bevt-00zct0
Postby AJ2008 » 12.09.14, 14:32
You need to be more specific as to the FW version you specifically need as many SA repairs will be fw-version dependent.What symptoms are you getting?
michel
Postby michel » 15.09.14, 21:09
Hard disk
mdl : wd3200bevt-00zct0
s/n : wx10e79ce260
dcm:dhntjhnb
lba : 625142448
this is in normal mode
Techno mode key
Heads number............................ : 3
Cyl Count............................... : 128
ROM version............................. : 08.87D
ROM generation.......................... : 08.87D
Link table version...................... : 02.8C.
Consolidated ROM version................ : 00080087
ROM Modules:
Heads number in use..................... : 3
Heads map............................... : 0,1,2
ROM Firmware version.................... : 00080087
Service area:
SA dir reading (ID)..................... : SERVO ERROR CODE BASE SvirActSync
SA dir reading (ABA/CHS)................ : Dir reading error ABA 88704 reading error Physical read error C/H/S: -128/1/1 - Device Error Detected: "SERVO ERROR CODE BASE SvirActSync"
Postby AJ2008 » 16.09.14, 09:52
michel wrote:Consolidated ROM version................ : 00080087
This is version you need. Did you try to short read channels to get SA access by ID? This will allow you to read off #11 and then you have a loader. Or at least can help identify the problem
michel
Postby michel » 16.09.14, 21:37
short read channels is it ( logging in normal mode changing spt dir ?)
if it is i tried
stil have the same message still want ldr update i try it by seaching database i load another id with
the space of 14gb .
i appriciate your help as i am new to these issues.
Postby AJ2008 » 17.09.14, 10:21
Does the spindle remain powered or does it stop?
I dont have this version to send you, but shorting and entering SPT should give some access or some better indication of the problem
Postby AJ2008 » 17.09.14, 10:24
I have version you need here:
http://www49.zippyshare.com/v/19308627/file.html
I tried to upload here but would not allow it, so I have to use some file share site.
michel
Postby michel » 18.09.14, 18:36
Yes sir , the spindle stops after a while.
So what does it means.
Regards,
Postby AJ2008 » 19.09.14, 11:24
It means there is very good chance that you have problem with drive mechanics (heads)
