WD DRAGFLY1 family : ldr Required :Wd5000AADS - 00S9B0
Posted: 25.06.14, 09:12
by micro999
Postby micro999 ยป Wed Jun 25, 2014 6:49 am
Wd - 500 gb : DRAGFLY1 family
Wd5000AADS - 00S9B0
DCM : HGRNHT2AGN
Techno mode key
Cyl Count............................... : 192
ROM version............................. : 90.82R
ROM generation.......................... : 90.82R
Link table version...................... : 04.0F.
Consolidated ROM version................ : 00900082
ROM Modules:
Modules directory address............... : 75 271
ROM Firmware version.................... : 00900082
Module search process started
Search method........................... : Search by ABA
ABA..................................... : 0
Size in sectors......................... : 184 300
ABA 0 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 1 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 2 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 3 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 4 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 5 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 6 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules found........................... : 0
Module search process completed
How to access modules ? Can anyone Give me loader file ?
Please help
Regards,
micro
Re: WD DRAGFLY1 family : ldr Required :Wd5000AADS - 00S9B0
Posted: 18.07.14, 20:38
by houman_2h
Hi micro999
I have 00900070
http://www.novinhdd.com/11-00900071.rpm
Posted: 21.07.14, 10:26
Try to block regions and check if you can get SA access then. but if you need loader then it needs to be exact version.
Alternatively, place donor PCB+ROM and use LDR relating to donor ROM, this will get you SA access and allow you to check for issues and save SA. Then you can reconnect patient PCB+ROM to check if problem is solved. If problem is not solved, use SA you saved to create hotswap donor.
