Need ROM for TAHOE XL WD5000AAKX-00ERM0 with FW ver 0005001D
Posted: 04.02.14, 09:57
by OHMYDATA
Hello I need a ROM for TAHOE XL WD5000AAKX-00ERM0 with FW ver 0005001D.
Please share^^
Re: Need ROM for TAHOE XL WD5000AAKX-00ERM0 with FW ver 0005
Posted: 04.02.14, 10:49
by waleed
Posted: 05.02.14, 02:19
by OHMYDATA
Thank you.
Please share all resources of .pcr ^^
Posted: 05.02.14, 04:29
by OHMYDATA
Your rom version is 0005001C
Do you have 0005001D?
Posted: 05.02.14, 09:11
This is correct loader.
Posted: 05.02.14, 09:42
by OHMYDATA
Is it ROM.BIN version?
My damaged hdd
11.rpm : 0005001E
ROM : ? (rom damaged unknown)
My Donor hdd
11.rpm : 0005001F
ROM : 0005001E
So i expect damaged rom version maybe 0005001D?
Posted: 05.02.14, 10:38
You are right. You need ROM with version 0005001D. It was assumed you read this version from some overlays on the SA which is why version 0005001C was uploaded.
Posted: 05.02.14, 19:56
by waleed
i'm so sorry for that
some times it make mix with me letter after and letter before as Mr. AJ2008 told and he is for sure right.
here is 0005001D rom vesion
https://www.mediafire.com/?t1w91bml8v59622
accept my apology again
Posted: 06.02.14, 01:45
by OHMYDATA
Thank you.
But the version is 0005000D , not 0005001D.
And If you have this version, please upload rom and rom modules.
Posted: 13.02.14, 02:37
by OHMYDATA
Is it possible to data recover with rom 0005001e.
Posted: 13.02.14, 09:59
If you have SA saved you can restore ROM manually. Select ROM Build from SA Data and point to mod #109 saved from SA. This will make convert 109 to compatible format to write. Next, enter Kernel mode and write new ROM file you create. Then re-power and write ROM modules from any version donor with same head map and model (family). Next, re-power and hopefully you will reach good ID. At this time you can choose to restore #47 from SA should you need to.
