WD5000BEVT-60A0RT0 LDR FILE NEEDED
Posted: 10.12.13, 10:45
by Imnew
Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 14.1HQ
>ROM generation.......................... : 14.1HQ
>Link table version...................... : 05.0P.
>Consolidated ROM version................ : 0014001H
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 0014001H
Re: WD5000BEVT-60A0RT0 LDR FILE NEEDED
Posted: 11.12.13, 08:22
by Imnew
Can I use LDR from database of ACE. Available LDR file is for ROM Firmware- 001400w
My HDD ROM Firmware version : 0014001H
Posted: 11.12.13, 10:19
Short read channels, input SPT, load from SA module 01 and write to static module to properly gain SA access, restart utility and re-enter SPT, now under 'view and edit resources' find module #11 and read via ID, save it to file and you have LDR
