Page 1 of 2
Need WD3200AAJB - 00J3A0 LDR and module
Posted: 07.03.11, 12:12
by Powermax
Hi to all.
I need WD3200AAJB-00J3A0 LDR and module.
Someone have it ?
Thank you
Re: Need WD3200AAJB - 00J3A0 LDR and module
Posted: 07.03.11, 13:33
by hassan
I have WD1600AAJB-00J3A0 01.03E01
But what is the problem of your drive?
Posted: 07.03.11, 13:40
by hassan
tHIS DRIVE IS Pinnacle PATA
Posted: 07.03.11, 14:19
by Powermax
Hi Hassan.
The problem is very strange.
When i connect Hdd to Pc3KUdma and power on, that go to ready, i do not ear any knock sound (it seem to make correct heads positioning) and the motor stay on
When run utility, it do not recognize it and it make me to enter in Kernel mode.
In kernel mode i can read ROM and ROM Module.
After bakup ROM data, i try to manually enter in normal mode. In this way i have a red messages that say "NO SA copy available".
Infact if i try to open Utility Status, i see the presence of 2 copy of SA, but both there are not flagged on.
At this point, with no SA flagged on, i try to read module anyway and infact i cannot read any of it, but if i try to run a SA structure check, i can see more module OK and a only one (Level A module T-List) bad.
I do not understand why SA structure chk can be read module and Reading module option cannot be read anything !!!!
I need LDR, for try to load it and see if i can read module with Module reading option
Thank you
Posted: 07.03.11, 15:20
by hassan
What is the F/w Version?
i have two F/W versios only
000100CD
000200CC
Posted: 07.03.11, 15:28
by Powermax
Is 200CB
Posted: 07.03.11, 15:55
by hassan
I think you can try to write a Rom with different version and try to Read SA and SA test
But befor read SA or run SA test open utility status and check the "SA SPT" set it to 1311
- Pinnacle PATA.zip
- Rom and Module 11 ver 000100CD and 000200CC for Pinnacle PATA family
- (645.05 KiB) Downloaded 430 times
Posted: 07.03.11, 15:58
by Powermax
Thank you !!!!
I try and after i tell you.
Bye
Posted: 07.03.11, 16:23
by Powermax
I just write ROM with 200CC and now i can read more module.
I see i cannot read T-List module and that is A Level module.
This case make me crazy
Posted: 07.03.11, 17:16
by hassan
Try to read tracks from head 0 and head 1 and see what is the corrupted reacks
then try to read this tracks composite mode
if this method does not success try to use
WD Marvell Dir module editing
viewtopic.php?f=35&t=7181
Posted: 08.03.11, 12:21
by Powermax
I just tried to read trk in composite.
I can read trk from 1 to 67. All over trk i cannot read.
I try to edit trk files and i see only trk1 have some data inside. All other trk are all to "00"
Posted: 08.03.11, 13:10
by hassan
Canyou perform the following steps
1- Write the Rom 000200CC power off/on
2- write original patient rom modules (0B - 20B - 47 - 30 - 0A)
3- exit kernel mode power off/on and start utility in normal mode
4-set SA SPT to 1311 in Utility status
5-go to menu Tests > Sirvice Information > Work with RAM > LDR file loading and lode module 11 000200CC
6-go to menu Tools > > Utility Extesions> HDD's resources view and edit > ABA Range > Select ABA of Region 0 and set the size of it and press ok
7-save the region 0 to file and send this file to me also send me please the error sector while reading the ABA
8- if you can send me also the ABA region 1
Posted: 08.03.11, 13:36
by Powermax
First of all, thank you for your help...
Second....
I just maked that you have write, but at point 6 the utility read only BAD and i cannot read selected ABA region
Posted: 08.03.11, 14:44
by hassan
Did you try with 000100CD version?
Is the loader success?
Can you read ABA region1?
Posted: 08.03.11, 15:05
by Powermax
Now try with 000100CD
